Engine Specific Info and Questions => IDI Engine => Topic started by: BK75 on September 15, 2011, 08:28:09 am
Title: no start (with a twist)
Post by: BK75 on September 15, 2011, 08:28:09 am
Victim:
Mk1 rabbit with an SB code GTD engine.  Bosch certified rebuilt pump 1yr ago.
Condition:
Only when fuel tank is half empty there is a suction loss between tank and pump if it sits for 6-8hrs.  Tank vents properly (also removed cap and condition still occurs).    Just started, maybe 1month ago.  Can't remember any change point at all; it has been running like a top since the engine swap.
So it does really start (hence the twist)  but it takes ~1 minute of cranking to pull the fuel back up to the pump.
Corrective actions:
Removed and torqued injector lines.  Replaced fuel filter.
Please help me diagnose!   Is there a check valve in the fuel tank (I don't find one in the Bentley).   How would fuel level in the tank make a difference?
Title: Re: no start (with a twist)
Post by: CRSMP5 on September 15, 2011, 09:30:23 am
pull float.. remove screen from bottom of the tank... its got alge build up on it and will do that... a coat hanger with a hook bent into it will catch the top hoop of the screen to remove it..
Post by: ORCoaster on September 15, 2011, 09:44:40 am
When you removed the fuel lines and retorqued them did you smooth sand the copper gaskets and then fire them with a torch till they blued?  I did that on mine and do not have the air in lines problem anymore.  Do you have transparent lines on the fuel filter to IP to see if air is getting in there?
Post by: Golf/Jetta on September 15, 2011, 08:41:46 pm
A check valve should be preventing the fuel from going back regardless if it has a pin hole somewhere. Better find out where it is getting its air from.
If you find out where its leaking in air and it's on the rubber lines where it connects to the hard plastic[/metal] flange, you can use a little fuel or oil around those seems to aid it in the seal. If it's still not sealing the area properly, I like to use gasket sealant (Silicone). Just don't crazy, you don't want it in the fuel line. Just in the edge and around a bit in the line to make a seal. Let it set before you tighten a bit, then wait, then tighten a bit more and so on... That should teach that line to leak.
There is also another check valve on the return line so the fuel doesn't go in the other direction.
That my opinion on how to deal with it but you still need to find where it leaking from. ORCoaster is also on the right track.
How long has it been doing that since the IPs rebuild?
Post by: CRSMP5 on September 15, 2011, 08:43:08 pm
rabbits have NO CHECK VALVES.... the slime on screen in tank does his issue... simple fix/check as thats first to look at..
Post by: ORCoaster on September 15, 2011, 09:01:46 pm
its got alge build up on it and will do that...  This has to be some sort of creature from the Black Lagoon.  Algae normally needs sunlight to live.  But it could very well be a life form that comes from those sea vents where bacteria live in super heated, arsenic laced water.
Maybe the next time I start seeing air bubbles in my lines I will attack the fuel tank monster living on the screen.  Never did check that one out although I did pull the fuel gauge sender out a time or two tying to get it to show a better range of full to empty.
Post by: fatmobile on September 15, 2011, 10:29:09 pm
Could even be the little lines between the injectors leaking air into the system.
Post by: CRSMP5 on September 16, 2011, 06:07:40 am
took less then 3 years to build it up on my 81 coupe..  :( was a gasser till i did the 1.6na swap in it.. and due to this time i kept refusing it was the issue... finally broke down.. removed the 3 screws and float unit to find a huge clear/yellowish slug looking thing grown into the screen...  :o
the ones i removed in the late 80s were always black in color..
so no idea what it is.. but it is so simple to check and remove.. would be my 1st look..
why full vs 1/2 tank... grows on it in a way it starves it of fuel.. then creates a suction when shut off when not covered in fuel..
Post by: 92EcoDiesel Jetta on September 16, 2011, 07:33:36 am
A full tank provides more pressure. That's why!
Post by: ORCoaster on September 16, 2011, 08:39:03 am
So what is it?  Crap coming out of the fuel?  Degraded hoses?  Sounds alien, that's it.  Aliens in our tanks, moving around between states in a manner that they can not be detected.  Very sly.
Post by: mtrans on September 16, 2011, 12:22:37 pm
You too?I hanting them from motor to IP to tank to motor to.......
Gremlins on disel/oil.
Post by: R.O.R-2.0 on September 16, 2011, 12:48:41 pm
algae actually does grow in diesel...
Post by: bajacalal on September 16, 2011, 01:12:20 pm
What's referred to as "algae" by diesel owners is actually a waterborne bacteria that feeds on the diesel.
Post by: R.O.R-2.0 on September 16, 2011, 01:22:22 pm
i never knew that, thanks for that piece of info..
it FEEDS on the diesel?
Post by: bajacalal on September 16, 2011, 03:57:58 pm
Yes, there are bacteria that will metabolize hydrocarbons.
Though, I think they need water to survive as well, so "algae" in your tank means water is in there as well, or at least it was in the tank where you bought it.
Post by: damac on September 16, 2011, 07:46:13 pm
You didn't run wvo did you?
What do you guys think of startron?  I used it on an old truck and the jetta a ways back because my wvo experiment starting pulling gunk off the tank walls, etc.   That was a nightmare but a couple new filters and a tanks of fuel to a bottle of startron seemed to do its job.
Post by: ORCoaster on September 16, 2011, 08:25:05 pm
From here:  http://www.diesel-fuels.com/
Contaminant build up resulting from excessive microbial growth and bio-degradation of diesel fuel can cause fuel filter plugging. Micro-organisms, bacteria and enzyme activity, fungus, yeast and mold cause diesel fuel degradation and the formation of waste products. The process is similar to milk turning into cottage cheese, a different form of milk. Of all the microbial debris and waste products in the diesel fuel tank only about .01% is "bugs". Even though microbes may cause and accelerate the process of fuel degradation, it should be clear that the waste products clogging your filter are not the microbes but fuel components which have formed solids.
Frequently, the application of a biocide aggravates the situation and turns bio-film into solids, creating a real fuel filter nightmare. Bio film develops throughout the entire diesel fuel system. It grows in the water-fuel interface and on the walls, baffles, and bottoms of fuel storage tanks. An unlucky end user may be filling up his fuel tank and getting this debris delivered as a part of his diesel fuel, for the same price as the diesel fuel.
I knew that there were microbes out there that eat diesel and other hydrocarbons I just never thought about them being in our tanks.  Talk about loosing miles per gallon.  Maybe we should all be thinking about this more as a problem when folks tell us they can't get the car running well after it was sitting for an extended amount of time.  They make biocides that kill this stuff but then you really better be changing filters often as it will float out as a solid later.
Just one more thing learned on this novel forum.
Post by: BK75 on September 17, 2011, 10:13:07 am
This is quickly becoming a thread jack.
I appreciate all the responses.    I checked the tank screen today; all clear.
I thought we were on to something with that since it would seem tank level related.   I agree with the suggestions of air in the lines I just can't ID where it is coming from.   And of course the purplexing oddity of it only occuring when the tank is partially empty is really wierding me out.   There are no bubbles during operation or when sitting, until the half empty issue starts.   Then I can't tell where.   I've tried to watch it for awhile after shutting it off and don't see anything, then come back ~5-8 hrs later and the clear line is empty.
Doesn't the tank level relationship to the symptom rule out anything pump/injector/engine side as being leak source?
Oh to the question of the relationship to the pump rebuild.   The pump was rebuilt about 14 mo ago and this issue started just a month ago.   I'm not sure where you were going with that but I will run every suggestion through.   It always seems to be my "that can't possibly be it" mentality that winds up biting me in the ass.
Post by: R.O.R-2.0 on September 17, 2011, 10:17:40 am
its only a thread jack when it has NOTHING to do with the original thread..
the algae in diesel is a GOOD reason to cause a no-start condition.. i faught algae all summer last year at the resort in alaska.. would have to change fuel filters every few days, on 30 boats.. so i was pretty busy..
if your pump was rebuilt 14 months ago, i would make sure its not a feed line restriction, then i would bring it back to the builder.. if he didnt fix it , i would then kindly throw it thru his front window..
Post by: CRSMP5 on September 17, 2011, 02:54:01 pm
ok screen clear.. that sa good thing...
next... how old is fuel filter? we know its diesel sucking issue.. just need to figure out where its got issues..
Post by: burn_your_money on September 18, 2011, 07:30:26 am
Maybe your fuel pickup or return in the tank has a pinhole leak.
Post by: BK75 on September 19, 2011, 06:38:42 pm
Wasn't able to get back to it yesterday.
I like the pin-hole suggestion.   That would follow the partial full symptom.   I think I can test that using my brake bleeder.
The filter was changed a few weeks ago.   It was the first thing I tried; before I realized it was fuel level dependent.
I'll be certain to post what I find next.
Post by: regcheeseman on September 20, 2011, 07:48:06 am
Is it not just a leak in the delivery hoses?
I'd be digging out my diesel diagnosis bottle....
Remove the lines from the filter and immerse them in a bottle half full of diesel.
Run the car, turn it off for the time that it takes for the problem to manifest and try to restart.
If the problem is still present then you can discount the tank, lines and filter from your enquiries!
I had the factory crimp on the join between clear and black hose leak - took me an age to find, simply because I assumed the fault couldn't possibly be there.
Post by: BK75 on September 25, 2011, 08:31:25 pm
I think I found it this weekend.   Trying to pressurize the line backward from the firewall a bunch of crud (don't have any idea what) came out of the line.   I haven't had a chance to drive it successively under half tank to prove it out but it seems like the likely culprit.
Thanks again for all the helpful suggestions.   The pinhole in the fuel line suggestion was what prompted the discovery.
Now back to my lurking.
Post by: ORCoaster on September 25, 2011, 08:56:42 pm
So this "crud" was keeping fuel from returning to the tank?  Did you capture the crud in a jar or bottle or fish it out of the tank itself?
Post by: BK75 on October 01, 2011, 03:46:16 am
The crud came out of the supply line, I guess I should have checked the return line as well.   I removed it by syphoning it out with the fuel like a vaccum through the access port.   It looked like dense fuzz, like the hair balls that form on the bottom of a pool.
Post by: 92EcoDiesel Jetta on October 01, 2011, 06:52:33 am
What consistecy and color is it?
Post by: ORCoaster on October 01, 2011, 08:38:02 am
Probably soft and gray.  Aren't all hairballs like that?  My guess would be black and like packed lint out of a dryer.  I am using his Crud word as my basis.
