Engine Specific Info and Questions => IDI Engine => Topic started by: erice1984 on March 18, 2011, 01:43:11 pm
Title: I bought an AAZ trying to comp test, what starter to use?
Post by: erice1984 on March 18, 2011, 01:43:11 pm
I have an AAZ, I have an 020 ASF transmission. I tried the stock direct drive starter, worlwide part number 16726, and the gear reduction 16947.
The direct drive (16726) almost stalls when it gets the cylinder near TDC.  This leaves me to believe that it can't generate the RPM's to get good psi reading.
The gear reduction starter (16947) goes pretty good, but I don't think it spins the engine fast enough to get the psi to build.  I haven't fully verified this yet, I am at the parts store typing this and going back home with this starter to actually run it for 15 seconds to see what psi builds up.
Can I use the AAZ starter?  Bosch part number SR0408X with the 020 transmission?
Let me know what you guys think.  Thanks  -Eric
Title: Re: I bought an AAZ trying to comp test, what starter to use?
Post by: R.O.R-2.0 on March 18, 2011, 02:34:17 pm
you need a diesel specific starter to crank over a diesel.. they are WAY BIGGER than a gasser starter, physically..
and they have about 3x the power too..
Post by: erice1984 on March 18, 2011, 03:12:21 pm
I understand, but gassers are rated 0.7-1.1KW, while diesels are rated 1.5-1.8KW
Both of these starters are listed as for diesel.  Both the specifications on them 1.8KW.
The only thing I can think of, is that my direct drive starter (16726) is weak from age, and not able to move the larger engine and possibly higher compression numbers because my 1.5 is fairly worn out.
I have no idea why VW offered a gear reduction starter that doesn't spin the same speed as the direct drive starter.
The AAZ starter, SR0408X is a direct drive unit, and spec'd at 2.0KW
I just wondered if anyone else has run into this issue and what solutions they came up with.
Post by: erice1984 on March 18, 2011, 05:40:55 pm
Okay, the gear reduc starter actually does a lot better job starting my 1.5..  Huge difference.  I don't hear the poor starter making the "I'm almost dead" *rrruhha..rrruhha..rruhha* noise while cranking (aka slow crank).
Well I compression tested my engine and it is not good, but I am still going to remain optimistic as it has been sitting for probably over a year.
So I believe it is my engine that is having the problems not the starter.
Post by: R.O.R-2.0 on March 18, 2011, 09:09:04 pm
all diesel starters ive read specs on, have been in the 2.1+kw range..
Post by: erice1984 on March 18, 2011, 11:02:46 pm
Let me know which ones those are.
Post by: R.O.R-2.0 on March 19, 2011, 10:20:05 am
the ones that come factory in mk1 and mk2 cars.. you know, the ones that weigh about twice as much as a gasser starter? ive read it a few different places that say the diesel starter is 3x the power of a gasser unit..
Post by: erice1984 on March 19, 2011, 10:26:59 am
rockauto.com states what the KW rating is.
So does Advance Auto parts
Short of contacting bosch or VW thats where I got my information from.
But yes there is a power difference between gas and diesel starters.  If there was one very powerful starter I could use I would like to know so I can use it!
Post by: Quantum TD on March 19, 2011, 10:32:21 am
How bad are the compression numbers? You might try soaking the cylinders with kerosene for a few weeks to  try to loosen up any stuck piston rings. Just be sure to 1) blow out the kerosene thru the injector holes/glow plug holes, don't glow the plugs when cranking, and drain the crank case and refill with fresh oil. If you get better numbers, run it for a short time, and then replace the oil and filter again.
I suggested this trick to someone on vwdieselparts.com and they reported improved numbers all around, and more-even numbers across the board. I'm gonna do it to the 3 turbo diesel motors I have kicking around here.
Post by: erice1984 on March 19, 2011, 10:34:17 am
Good idea.
I added 1/2 qt of ATF to the oil to loosen stuff up before I tested.  My numbers were 300, 360, 330, 280
I'll try it.
Post by: R.O.R-2.0 on March 19, 2011, 10:40:26 am
like i stated, mk1 and mk2 starters are the gigantic, direct drive starters.. they require good cables, and a good battery or else they will not spin fast enough..
any starter is kinda *marginal* for an engine with 24:1 compression.
Post by: erice1984 on March 19, 2011, 10:45:02 am
I hear ya, I had the battery out of my car, has 800CCA was fully charged.  I was using jumper cables, I think they were 6 AWG or something.  but 12ft long.  I should make a better setup for the next go around (I have 0 and 2 AWG laying around and keep the cables to less than 2 ft).  I had my charger on the battery, it was only pushing out ~6 Amps but I would wait until my multimeter would read 13.0volts and then hit the starter again.
I almost guarantee its because the engine has been sitting for so long and all goo'd up.
Post by: R.O.R-2.0 on March 19, 2011, 10:49:11 am
hmm, im thinking that you used too small of wire to power the starter.. 6g is small.. and especially such long runs of it..
jumper cables are great for starting a dead car, but not good for connecting a starter to a battery.. they dont handle enough current..
Post by: dieselweasel on March 20, 2011, 04:37:59 pm
I'm thinking you're right...lots of voltage drop along 6 awg wires 12' long.  Also the small surface area of the clamps contacting the terminals doesn't help matters.  I'd rig up some of that 1/0 you have with proper terminals and redo the compression test...you can then use them for battery cables.
Any starter I've seen on an AAZ was gear reduction.
Post by: Otis2 on March 20, 2011, 10:20:51 pm
I use that starter in my AAZ-powered Vanagon.
Good, high compression in the engine, but it starts like butter, even when it's warm and the glow plugs don't glow.
Long stretch of battery cables (gasser cables & battery box position), probably marginal for the task, but the Bosch SR0408X stands up just champion to all the abuse.
Just another data point to be considered.
Post by: coke on March 20, 2011, 10:51:36 pm
All 3 of my MK2's had gear reduction starters, and they're not nearly as big as the "direct drive" that my 84 and 83 had.
Post by: erice1984 on April 25, 2011, 08:12:13 pm
I prefer a leakdown test over a compression test, especially if there are any issues with cranking the engine over.  Better info and easier to perform.
I agree with you here libby.
I tested the engine again tonight after putting pb blaster in the cylinders, seafoam a few days later and then filled each cylinder with about 2 cups of diesel and let sit for 6 weeks, then changed the oil.  I fear I may have let it all sit too long and possibly ruined some of my hopes for improvement.
My numbers are only slightly better.
Original: 300, 360, 330, 280
New: 380, 380, 300, 300
This was on a mediocre battery.  It was tested as being good, but definitely not the same one used as before.
Seeing how the test showed slight improvement I am going to just tear the engine down and give it a good rebuild, maybe re ring it as well.
I used approx 2 feet of 2 gauge wire from battery to starter unlike before using 12ft jumpers.
