Engine Specific Info and Questions => IDI Engine => Topic started by: myvolkswagen on August 28, 2010, 08:55:56 pm
Title: 1.6 mls headgasket
Post by: myvolkswagen on August 28, 2010, 08:55:56 pm
I read that 53 willys ran one of these and from what i understand it is custom. How can I get one of these without going through a whole lot of trouble? Anyone else running one of these or something else that will hold up a little better than a stock hg? thanks
Title: Re: 1.6 mls headgasket
Post by: theman53 on August 28, 2010, 09:30:38 pm
If you have a hydro head then just buy the correct thickness 1.9 aaz HG, it will bolt right up. If it is a mechanical head check out 53 willys stuff and he will tell you where to get stuff
OR
Saurkrat has some threads about blocking off the extra coolant passage. I did as well if you check my build thread.
http://www.vwdiesel.net/forum/index.php?topic=11786.45 (http://www.vwdiesel.net/forum/index.php?topic=11786.45)
http://www.vwdiesel.net/forum/index.php?topic=15780.0 (http://www.vwdiesel.net/forum/index.php?topic=15780.0)
Post by: myvolkswagen on August 28, 2010, 09:41:21 pm
Oh the aaz one will bolt up to the hydro 1.6?! Wow thanks you just saved me $100. Thought I would have to have it custom
Post by: theman53 on August 28, 2010, 09:52:21 pm
Yep 100% bolt on. Just measure for piston protrusion and you are in there like swimwear.
