Engine Specific Info and Questions => IDI Engine => Topic started by: morgoon on August 14, 2010, 11:45:54 am
Title: IP id?
Post by: morgoon on August 14, 2010, 11:45:54 am
I had some questions regarding the differences in these two IP's
1981 Rabbit
This one is of my early 1.6, at least that is what I think it is
It was mentioned in my intro post back in April, that someone thought it was an early 1.6
(http://i1020.photobucket.com/albums/af324/morgoon/198116IPSmall.jpg)
with these numbers
(http://i1020.photobucket.com/albums/af324/morgoon/198116IPtagSmall.jpg)
This pump is on 1.5 I hope to put in place of the ailing 1.6
(http://i1020.photobucket.com/albums/af324/morgoon/15IPSmall.jpg)
with these numbers
(http://i1020.photobucket.com/albums/af324/morgoon/15IPtagSmall.jpg)
These pumps look so similar, are they interchangeable..
As it must be obvious to everyone else, these two pumps are different than the pump on a worn out 1.6 I bought to tear down and learn on
You can just make out the can under the ip in the first photo, it leaks a bit but it runs
The other one hasn't seen a drop of diesel in 17 years
I would like to send the 1.5 pump to Giles, but I wondered if I could get buy with a reseal on the (top photo) pump
I have little experience with this stuff, so any help is much appreciated
Title: Re: IP id?
Post by: 84tdrabbit on August 14, 2010, 11:52:23 am
look at the numbers, they are the SAME PUMP..
did you need to start a thread about that? the numbers are plain and bold. same pump.. part numbers are the same.
next time, just look at the part numbers..
Title: Re: IP id?
Post by: Vincent Waldon on August 14, 2010, 12:15:23 pm
Deleted your account again Kevin aka Rabbit on Roids.... we have zero tolerance for your disrespectful posts, as has been explained to you many many many times.
Title: Re: IP id?
Post by: Baron VonZeppelin on August 15, 2010, 10:27:07 pm
068 130 107 A
Shows to be 77-80 1.5 with manual tranny.
Since both have same number, they both are that same application.
If its running satisfactorly enough on the 1.6, i'd go with it.
i don't know what all would be difrnt on the inside of 1.5 vs. 1.6 pumps - just guessing maybe slightly lower overall fueling.
Perhaps read up on the DIY's of resealing - and do a trial run (dry run without new gaskets) on the pump that has been sitting 17 years before tackling the running pump.
A guy on eBay sells Bosch NA pump rebuild kits WITH the front seal included for $20. You could send him the numbers from your pump to double check if his kit will be suitable.
http://cgi.ebay.com/ebaymotors/VW-Diesel-Bosch-VE-Injector-Pump-Rebuild-Kit-Injection-/250664333516?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item3a5cc230cc (http://cgi.ebay.com/ebaymotors/VW-Diesel-Bosch-VE-Injector-Pump-Rebuild-Kit-Injection-/250664333516?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item3a5cc230cc)
This listing has ended, but you can click on view other items, etc...
Several on here have purchased from him.
Title: Re: IP id?
Post by: morgoon on August 16, 2010, 09:03:01 am
Thanks that was very helpfull
Title: Re: IP id?
Post by: rs899 on August 16, 2010, 11:34:07 am
I got that seal kit and its a very good deal, but the guy won't answer any questions.
FWIW I had 2 pumps apart this weekend, one had castings dated 1977 ( I assume 1.5 ) and one 1980 ( I assume 1.6).  The only difference I could SEE was the one corner of the front mount (triangle) was slightly different on the '77 , the governor had some see-though holes and the governor spring was slightly different.  I don't know about any internal (valving) differences but there might be some.  Actually, come to think of it , I had to use the cam plate from the '77 in the '80, and IIRC (now) the lift ( timing) spec is different.  Too bad I didn't think to compare them..  oh wellllll.......
Title: Re: IP id?
Post by: GTD_MK2 on August 16, 2010, 05:07:46 pm
One of the differences of a 1.5 to a 1.6 pump is the governor spring, the 1.5 has got a stiffer spring for a higher rpm limit
