Engine Specific Info and Questions => IDI Engine => Topic started by: MoparEd on April 10, 2010, 09:50:41 pm
Title: AAZ Rebuild Help Needed
Post by: MoparEd on April 10, 2010, 09:50:41 pm
Hi all,
I have been stalling my engine build because of how the machine shop had installed my IM shaft bearings. I need to get this engine built and running by the end of the month.
I think im just going to purchase new IM shaft bearings and find another shop to install them for me. Im not pleased with the last engine machine shop as they rather argue with me than own up to a bad bearing install.
I did some searches about the IM shaft bearing installs, and found out that the IM shaft should turn freely by hand with new bearings. I have to use a wrench to turn mine. and thats with nothing in the block but new IM shaft bearings and the IM shaft.
They are Clevelite bearings.
Can anyone suggest a pre sized IM shaft bearing set? Part number?
Anyone know of a shop in the Greater Toronto Area that can do the Install?
Thanks
Ed
Title: Re: AAZ Rebuild Help Needed
Post by: starrd on April 11, 2010, 12:31:46 am
I think this covers most of the info you need:
http://www.vwdiesel.net/forum/index.php?topic=1676.0 (http://www.vwdiesel.net/forum/index.php?topic=1676.0)
Post by: MoparEd on April 12, 2010, 06:34:17 pm
Can anyone tell me which way the inner IM shaft bearing goes? Im talking about the one with the groove in it, its installed but im not sure if its in the right way. The groove is on the flywheel side
Thanks
Ed
Post by: rabbitman on April 12, 2010, 08:22:23 pm
Thanks
Ed
The groove is supposed to shoot oil at the vac pump/int shaft gears so just point it that way.
Durabond               - VWG-1
Clevite                   - SH1209S
Post by: MoparEd on April 12, 2010, 08:40:48 pm
Thanks rabbitman,
Its pointing in the right direction then. I ordered new clevite bearings part number SH1209s today (good thing the machine shop gave me all the boxes the parts came in lol). Just have to replace the outer one the machine shop installed wrong and scratched up the surface. The inner bearing is fine and installed correctly.
Thanks again
Ed
