Engine Specific Info and Questions => IDI Engine => Topic started by: parkdog on December 03, 2009, 09:46:09 pm
Title: Weird engine Squeal help?
Post by: parkdog on December 03, 2009, 09:46:09 pm
i just changed all my belts on my 1.6td jetta but it still makes the noise that an old or loose belt would the alternater was rebuilt before i got the car. It does it sometimes when i make a sharp turn. also when im driving if i psh the clutch in it will stop any suggestions?
Title: Re: Weird engine Squeal help?
Post by: rabbitman on December 03, 2009, 10:47:37 pm
Sounds like something tranny related.
Post by: Smokey Eddy on December 04, 2009, 02:32:59 am
yeah if you hadn't said the part about the clutch i was going to say ... your battery could be dead and the load on your alternator is causing the belt to slide and make a squeal OR if the plastic cover has come loose and it's rubbing on the accessory belt that also can cause squealing.
Also, if you put the timing belt tensioner on backwards it will offeset the belt and it will squeal but i don't think that's the case.
Is there oil in the transmission? :P
Post by: truckoSaurus08 on December 04, 2009, 05:57:14 am
You migh have worn pulleys.
Post by: 8v-of-fury on December 04, 2009, 06:09:15 am
take off your pulleys and rough them up with a wire wheel. When they go smooth they have trouble getting traction on belts and thus they slip and squeal.
Post by: clbanman on December 04, 2009, 09:16:02 am
If it is more or only noticeable in 5th gear then I would say it is definitely transmission oil level.
I have what sounds like a similar issue on my car if I don't keep the alternator belt tight.   It usually starts when raining (belt wet) and if I don't do anything it gets worse until it does it even when dry.   I have noticed that pushing in the clutch or putting the trans in neutral will stop the noise - if I release the throttle.  This is really only because it drops engine rpms to the point where the belt can "grab" the pulley again.
Post by: Rabbit on Roids on December 04, 2009, 09:18:27 am
all 100% true ^ ^ ^
except that i have to rev my car up to get the belt to quit squeaking. it idles a little high, i imagine every intake gasket leaks.. but it wont catch at low RPMs, i have to rod it to like 5 grand then let off. probably has alot to do with the powerful amp in the trunk..
Post by: burn_your_money on December 04, 2009, 09:32:19 am
Is the noise constant?
Does it do it in neutral?
What effect does revving the engine have on the sound?
And as always, my cure all solution, the voltage drop test
http://www.vwdiesel.net/forum/index.php?topic=22321.0 (http://www.vwdiesel.net/forum/index.php?topic=22321.0)
Post by: bajacalal on December 05, 2009, 08:41:20 am
If this noise stops when you push the clutch in, I would think it's transmission related or something like the throwout bearing (or whatever it's called in our backwards transmissions). My car has started doing this same thing but the noise stops when it's warmed up or when I push the clutch in and I know the transmission is due for an overhaul.
Post by: parkdog on December 05, 2009, 10:35:20 am
the noise isn't constant it does do it in nuetral and it only started doing it when it started to get cold.
Post by: Rabbit on Roids on December 05, 2009, 10:42:08 am
check the bearings in your alt. i bet they are getting ready to take a dump.
Post by: parkdog on December 05, 2009, 10:47:12 am
ok yeah i thought it might have been the idler pulley but when i checked that it was smooth ive never worked on an alternator before tho.
Post by: parkdog on December 05, 2009, 11:18:49 am
ok so upon further inspection i  watch the belts as they are running  the alternator belt is tensioned all the way but it still looks loose when the engine is running  you can see it kinda whip back and forther could this noise be due to that? the lady i bought the car off said the alternator was rebuilt and she said they couldnt figure out the noise so maybe its just the tension? i wont cancel out the suggestion of alternator bearing being the cause tho.
Post by: Rabbit on Roids on December 05, 2009, 11:44:43 am
the pulley may be bent a little bit, or out of round. all it takes is a little zing to the pulley and its bent. then the bent spot has more or less tension depending on how it got bent.
Post by: Black Smokin' Diesel on December 05, 2009, 05:50:02 pm
I would remove all the belts to see if it's coming from the timing belt. You don't want that one to break. The tensioner could be the culprit. Don't run the engine too long as the waterpump isn't spinning. What accessories does the car have? Start by re-installing the belts one by one to help you find the problem.
Post by: ozzie on December 05, 2009, 08:00:21 pm
I had a similiar situation - alt bearing
Post by: parkdog on December 07, 2009, 02:49:43 pm
i dont think its the timing belt cause it didnt do this in warm weather it didnt start doing it till it started getting cold here. i probably wont be able to work on it or a while now since its -20 celcius here now and the garage i use isnt heated.
Post by: Henchman on December 09, 2009, 04:51:24 am
I am suprised no one has suggested the power steering system.  PS fluid is hygroscopic, and needs to be changed much more often than people usually go (I do a flush every 3 years).  Since you mentioned that is sometimes starts when you go hard lock with the steering, I would try replacing the fluid.  This would also explain why it gets worse when it gets colder.
Ian
Post by: 8v-of-fury on December 09, 2009, 06:27:57 am
This would go right along with PS fluid.. sounds like an older ford lol!
putting the clutch in reduces engine rpm's and thus reducing PS pump rpm as well.
Post by: Rabbit on Roids on December 10, 2009, 08:51:19 am
disengaging the clutch makes engine RPM rise, its turning less rotating mass. it doesnt add more load to the engine slowing it down.
Post by: Henchman on December 10, 2009, 09:28:08 am
Insert Quote
Quote from: 8v-of-fury on December 09, 2009, 06:27:57 AM
Quote from: parkdog on December 03, 2009, 09:46:09 PM
Not if he was driving around at the time the clutch was disengaged, then RPM would drop.  And as 8v-of-fury said, the first thing I thought of was my 90's fords that used to make that squeal when fluid was not maintained.
Ian
Post by: Rabbit on Roids on December 10, 2009, 09:44:26 am
ok, well thats considered decelerating. i hadnt thought of speed yet.
Post by: 8v-of-fury on December 10, 2009, 06:50:16 pm
yup in my my post i quoted a quote that the OP said while driving pushing in the clutch makes the noise stop. so it is engine Rpm related. because the trans, and axles maintain the same speed you are driving at, unless your hitting the brakes.
Post by: Rabbit on Roids on December 12, 2009, 07:46:18 am
its gotta be belts. or alt bearings.
