General Information => General => Topic started by: burn_your_money on November 16, 2009, 09:38:33 am
I know there are a lot of different dyno sheets on the forum but they are scattered all over the place. If everyone that has one could post it here along with a brief description of what you have done to the engine that would be swell. TDI, TD, NA and anything else you might have :) VW Diesel engines only please.
i will start
jk engine converted to turbo
kkk24 at 30psi,big front i.c.,upped fuel.
(http://img126.imageshack.us/img126/4166/dyno16gtdvy1.jpg)
1V ECO diesel with nothing but the following changes:
- Passat 1.6TD intercooler mounter on top of gearbox (not a lot of airflow)
- Boost pressure adjusted to 1,1bar = 16 psi
- Fueling and idle adjusted
Results at the hubs (Dynapack):
- 91.7hp @ 4112rpm
- 182.1Nm = 246.9ft-lbs @ 2890rpm
Lots more to come ;)
(http://i14.photobucket.com/albums/a345/Alcaid/Dyno151009.jpg)
91 Golf NA. Stock run plus a stock+Giles pump run
(http://img.photobucket.com/albums/v603/burnyourmoney/StockVSPerfpumplegend.jpg)
1984 Jetta Deluxe 1.6 IDI na
200K+ miles (estimated, odo had stopped for a couple years before I got it)
Stock pump (I think...), recently resealed by me
Stock intake and filter
Stock exhaust
Ran in 4th gear with 7A transmission
Shell ULSD w/ a few oz's of Stanadyne treatment
Difference in runs: first run (lowest), fuel screw set to almost no smoke at WOT, second turned in 1/8th, third another 8th and lots of smoke at WOT.
(http://i682.photobucket.com/albums/vv182/hignight17/84%20Jetta/Josh-jetta.jpg)
I don't have a dyno sheet for the full view of TQ and HP, but have the end result.
Running 30PSI of boost to 6K RPM.
(http://i232.photobucket.com/albums/ee10/joshmarstall/IMG00290-20101006-2041.jpg).
This was the first run, stock boost at 10-11PSI.
(http://i232.photobucket.com/albums/ee10/joshmarstall/IMG00289-20101006-2003.jpg).
Its cool what boost can do.
Nice hp 8) Whats your setup, torque seems low? A big turbo that starts to choke upper rpm at 30psi? Could you get dyno sheet, always intresting to compare :)
Here's my latest. Had to get a dyno sheet for MOT, so there is't everything. Later I found that timing was set at 0.60mm, maybe that had something to do with upper rpm range ::) I should go again, but 4wd dynos are not that common here.
(http://i13.photobucket.com/albums/a297/mattif/80q/th_img006.jpg) (http://s13.photobucket.com/albums/a297/mattif/80q/?action=view¤t=img006.jpg)
1,9NA, KKK14-2 (MB om606) with AFN exhaust manifold, some porting in head, custom mech cam with rosten valvesprings and 10mm pump.
MJF- What boost do run the k14-2 at? What do you think its capable of on a 1.9 idi?
Staying ot heres my peugeot 1.9 xud9 idi print out, 11mm pump and k14-2 from om606, still on standard tmic! ;)
(http://i670.photobucket.com/albums/vv66/del635/dyno-noreg.jpg)
It was at 1,5 bar. IŽm expecting ~200hp (crank), but weŽll see.
