Engine Specific Info and Questions => Non VW Group Diesel => Topic started by: dennis on November 13, 2009, 08:52:48 am
Title: Turbo noise
Post by: dennis on November 13, 2009, 08:52:48 am
My 240 Volvo wagon makes a noise that sounds like turbo whine, but is NA. Goes away when you let off the throttle. Pitch change with throttle change. Pretty strange. I though it was noise from the radio at first, but does not go away when the radio is off. It is a d24 engine which is the same as a VW 1.6 but with two extra cylinders.   ???
Title: Re: Turbo noise
Post by: Syncroincity on November 13, 2009, 06:43:47 pm
Pitch changes with engine speed, or throttle position?
I'd check your belt covers first, make sure nothing's rubbing, or come loose.
Post by: burn_your_money on November 14, 2009, 10:10:44 am
I'll take a guess at a restrictive exhaust coupled with a pin hole leak near the manifold
Post by: dennis on November 16, 2009, 06:23:39 am
Throttle position. Mostly from part load to ful load. If I completely let off the throttle the noise stops.
Post by: dennis on November 16, 2009, 06:30:52 am
Thats a thought. Actually planning a turbo engine later, so a bigger exhaust would not be in vain.
