Engine Specific Info and Questions => IDI Engine => Topic started by: truckinwagen on October 22, 2009, 02:49:58 pm
I am about to hone the block for a re-ring, and am wondering if I will need to have the block hot tanked.
I know that it is a good idea after machining to hot tank a block to get rid of any shavings, but does honing really count?
I am tempted to get it tanked just to get rid of the grime on the outside of the block, but it costs $80 so if it is not necessary I don't really want to.
does honing require a hot tank wash?
-Owen
traditionally no. a good clean with rags and kerosene is considered OK.
if i had hte option, i'd probably do it if it wasnt a hassle - then you can paint the block and make it all nice :-)
I just did mine a few months ago, the majority of the stuff simply sticks to the honing stones, just keep everything well wetted. I used a wire wheel with blue shop towels around it to clean up the bores afterwards.
good to hear, I probably wont to a hot tank then as I want to keep costs down, and that makes $80 I can spend somewhere else.
Yeah, hot soapy water and a rag is fine, just be sure to oil it right after.
I had the bottom end off, so I cleaned the outside of the block first with foamy engine brite and wire brushes, then honed it. After I honed it, I flipped the block over and used a few cans of brake cleaner and a dollar store dish brush and rags to clean up the bore. I used an old white T shirt to check and see if the bores were clean, as well as the mating surfaces. I think I was out a total of 25 bucks for a nice shiny block.
at most...
i used my bath tub once. filled it completely up with as hot of water as i could. then let the block sit in the water and get real good and hot. then cleaned it real good and took it out. dried in a matter of minutes.
Tell me you were single when you did that! If my lady came home & a nasty old diesel block was in her tub... i think thermonuclear would be a proper description!!
As for the block, go buy a 6 pack & go find someone who likes beer & has a hotsy steam pressure washer, that'll clean it out real nice! I can't imagine they are rare up there.
+1 :o It is a good idea though ;D Just means I'd be sleeping outside under the apple tree for a few months.
LMAO my wife would pull my arms off and beat me with the moist ends
I prefer the dishwasher with some of that Purple Power degreaser stuff.. Works well, and no spots! ;D
see, you guys all have wives to deal with. or girlfriends. they are a pain in the ass. females annoy the crap out of me. >:(
Water plus TIDE laundry detergent
TIDE is high in phosphates and clean nicely. It's a nice little trick I learned from my shop's tolken mopar guy.
What kind of tide? Liquid, powder?
Powder, you mix it into a paste and brush it in. I completely forgot about this old school trick. It cleans hands awesomely after a day in the shop. There is one catch though, you know where all your cuts and scratches are.
I cleaned the intake off my old SHO (big arrangement for those who don't know) but we lived in an apartment at the time and I did not have access to a pressure washer, altho it just occured to me know, 10 years later that I could have taken the intake to the self car wash.
Next time,
Ian
I've worked for 20++ years as an automotive machinist-currently building mainly hi dollar vintage race motors. what I do is use acatone or paint thinner and clean paper towels. I wet the towel-wipe in a circular (following crosshatch) pattern. do this a couple of times untill you can take a fresh towel and see nothing on it. I have used the hot water + dishsoap method (works fine-just make sure you wipe it down with wd 40 after) or just used wd 40 + keep wiping till a clean one show no residue( might take 3 or 4 times).
Yup.
I knew the machineshop I dropped the block at to get machined was ok - I saw a box of tide sitting on the windowsill when I walked in.
use that in your radiator too when you blow a head gasket. the granules kinda scour the radiator and clean it spotless too!
