Engine Specific Info and Questions => IDI Engine => Topic started by: 87octane on September 18, 2009, 03:22:06 pm
Does anybody have an AAZ intermediate shaft pulley lying around to pull the part # and measure the diameter where the belt runs?
PM me if you'll sell me the pulley. Thx.
"FrankenDiesel"
I have an IM shaft pulley I would be willing to sell you, I am not sure it was originally on an AAZ(I would doubt it actually) but I do believe that all the diesels had the same size IM pulley.
I got a pretty firm recommendation from a huge vw diesel engine building outfit that the 1.9 AAZ int shaft pulley is specific to the 1.9 block just like the vacuum pump is.
Still looking for a part # from anyone...
I just was looking for this for someone else. The number on Vagcat is 028 115 021 B . I didn't cross reference to see if has an other engine application though.
you can't use a 1.6 vac pump on an AAZ?
[/quote]
Correct. 1.6 has 1.25" diameter and 1.9 has 1.75" diameter.
Anybody need a 1.6 vacuum pump, vane style?
That's right, 1,9 pulley is smaller than 1,6. I don't have measures right now, but could measure when get home.
I just checked. The pulley i listed is 1.9 diesel non TDI specific.
Kudos to Jeff at Acme Adapters for these details:
1.6 pulley 4 3/4" diameter, lip front and rear
1.9 pulley 4 1/4" diameter, NO lips either side.
way easy to spot in a box spares...
Who's got one?
