Engine Specific Info and Questions => IDI Engine => Topic started by: allsierra123 on August 30, 2009, 08:08:15 am
Title: How much is too much black smoke.
Post by: allsierra123 on August 30, 2009, 08:08:15 am
I just got my 1.9td running. It idles great moves around good. But when I get going and it hits around 2000 rpm Its puts up a rather large smoke screen. It pulls pretty hard it just smokes a lot. At idle I get none. but when I rev it it puffs it out there pretty good. I have done nothing to it so far. And the only electrical parts I used to hook it up is the fuel stop and the glow plugs. I did notice there are a few connectors on that IP that I dont have hooked up But I dont know what they do. Also it seems to be worse after the engine up up to operating temp.
Title: Re: How much is too much black smoke.
Post by: Rabbit on Roids on August 30, 2009, 08:13:52 am
either turn the fuel screw down, or turn your boost up so you can burn all that black.
Post by: allsierra123 on August 30, 2009, 08:33:11 am
Well I need to find the fuel screw on this pump.
Post by: Rabbit on Roids on August 30, 2009, 08:45:10 am
its most likely in the same spot they have been in the last 20 years. on the back of the pump near the top. has a stop collar on the screw so you can only screw it in a little ways.
Post by: 410 on August 30, 2009, 04:20:26 pm
Some of the 1.9td turbos had a vacuum line going to it along side the boost sensing line.  If it has this vacuum line going to the turbo from a solenoid on the passenger side fender well disconnect it.  When vacuum is applied to this line the wastegate opens sooner.
Post by: smoken u on August 30, 2009, 07:25:26 pm
hmmmm well you say you have done nothing to it so i am assuming that the boost levels and fuelling are all at stock levels, I dont have alot of experience with the injector pumps on the 1.9L but i would imaging that those electrical connections are of some importance, another possibility is a stuck wastegate or maybe worn out injectors??
Post by: allsierra123 on August 30, 2009, 09:31:48 pm
Im kind of inclined to agree with you on those connections. Also it does have some sort of vacuum line on the top of the pump.
Post by: 410 on August 30, 2009, 09:49:01 pm
Don't disconnect the line on the top of the pump.  Thats your lda and it's a pressure line not a vacuum line.  Check to see if you have two lines going to the turbo.  If there is two, the small one is a vacuum line designed to reduce boost pressure under light load conditions.
Also, sounds straight forward but make sure your air filter is clean.  A severely plugged air filter can cause lots of smoke.
Post by: allsierra123 on August 30, 2009, 10:07:00 pm
yeah there are 2 lines on the waste gate.
