Engine Specific Info and Questions => IDI Engine => Topic started by: Kantdrivefast on April 01, 2009, 04:15:26 pm
Title: Pre cup cracks....
Post by: Kantdrivefast on April 01, 2009, 04:15:26 pm
Well I got around to taking the head off and found these.
(http://i147.photobucket.com/albums/r317/casman66/IMG_9177.jpg)
(http://i147.photobucket.com/albums/r317/casman66/IMG_9179.jpg)
(http://i147.photobucket.com/albums/r317/casman66/IMG_9180.jpg)
(http://i147.photobucket.com/albums/r317/casman66/IMG_9178.jpg)
How bad are these. Worth rebuilding?
Post by: burn_your_money on April 01, 2009, 04:25:43 pm
daily or race car?
Post by: Kantdrivefast on April 01, 2009, 04:30:14 pm
Daily with a little more fuel and boost.
Nothing too fancy.
Whats the verdict..... find a new one? Or put this one together?
Post by: RabbitJockey on April 01, 2009, 04:47:48 pm
can you get just new pre cups?
Post by: Kantdrivefast on April 01, 2009, 04:52:39 pm
Where from. I searched the thread and all I could come up with was that new ones are pretty much pure unobtainium.
I was also referring to the cracks inbetween the valves. Are they too large?
Post by: jtanguay on April 01, 2009, 05:03:50 pm
new swirl chambers are available.  i recall viewing a post linking to a vendor that listed a plethora of different chambers of all types for all makes.  don't know where it is now, and a search might take a while to sift through.
Post by: bigblockchev on April 01, 2009, 05:30:01 pm
I wouldn't worry too much about the cracks between the valves they are pretty normal. Bentleys even gives a spec for the max size and those don't look even close. Cheers Dan
Post by: diesel smoke on April 01, 2009, 08:45:05 pm
You got to get ahold of this guy: http://forums.tdiclub.com/member.php?u=31923
He does IDI heads too. I'm going to send him the one from my '89 for a complete refurbishing. It needs it.  8)
Post by: RabbitJockey on April 02, 2009, 01:44:24 pm
will a 1.9 precup fit in a 1.6 head?
Post by: jtanguay on April 02, 2009, 09:03:49 pm
Quote from: "Trev0rbr"
i'm pretty sure they're a bit bigger.  which is why using the 1.9 head on the 1.6 makes it a little harder to start.
frank06 on TDIclub only does TDI heads though right??? maybe he can get the swirl chambers though?
Post by: diesel smoke on April 02, 2009, 09:16:27 pm
Quote from: "jtanguay"
Nope, he can do both IDI and TDI. You would have to ask him about the swirl chambers though. 8)
Post by: jtanguay on April 02, 2009, 09:26:46 pm
Quote from: "diesel smoke"
ah pretty cool!  hopefully he doesn't charge too much.  those new chinese heads are very cost effective  :lol:
Post by: diesel smoke on April 02, 2009, 09:39:56 pm
I don't even know where one could get a genuine German head... :x
Post by: Vincent Waldon on April 02, 2009, 09:40:56 pm
My vote... for a daily driver the head appears fine... cracks between the valves are smaller than many I've seen (in general a dime is the thickness limit), and the pre-chambers are beginning to show some stress fractures but given how thick they are they probably have many many miles left.
I'd have it surfaced, rebuilt as required (guides, seals, etc) and carry on.
Post by: Smokey Eddy on April 03, 2009, 03:26:32 am
As another reply to the valve cracks coming from a guy who had to get a new head because of them....
my cracks in my 1.6head were enormous in comparison. An actual gap. Just visible cracks are nothing man. I wasn't so forum savy back then and i didn't think to take pictures of how big they were to show how big mine were to screw over my cooling system.
I later threw it into the local "transfer station" pit with much rejoicing following.
Post by: Smokey Eddy on April 03, 2009, 03:29:19 am
Mine hasn't grenaded yet!!!!!! and that's with max stock fueling and ZERO boost control!!! 20 psi regularly.
Post by: Kantdrivefast on April 03, 2009, 01:57:33 pm
Quote from: "Vincent Waldon"
This was the kind of reply I was looking for. Thanks vince. Now, head resurfacing? Machine shop does this I imagine or can I just run a flat block on it with 1000 grit or so, and if it goes to the machine shop do the precups have to come out, and should I peen them in? And if I do, how would I go about doing it.
So many questions... so much left to do.
Post by: MJF on April 04, 2009, 01:35:46 am
There are 2 size of 1,9 precup. Other (earlier?) will fit to 1,6 head, but has bigger opening. The other is smaller in diameter and will not fit.
