Engine Specific Info and Questions => IDI Engine => Topic started by: vixentd on January 28, 2009, 09:57:50 pm
Title: 1.9 aaz passat transmission question
Post by: vixentd on January 28, 2009, 09:57:50 pm
Will a tdi transmission bolt up to this motor and lower my rpm range?  Stock axles bolt up and linkage?
Will a golf or jetta transmission work?
Thanks
Title: Re: 1.9 aaz passat transmission question
Post by: MJF on January 28, 2009, 11:08:44 pm
Quote from: "vixentd"
Yes
If it is TDI.
Post by: burn_your_money on January 29, 2009, 04:58:03 am
Pretty much exactly what MJF said. You'll want to get a 02A transmission
Post by: MJF on January 29, 2009, 06:24:46 am
All Passats have 02A from factory.
Post by: stewardc on January 29, 2009, 06:27:25 am
I think the AAZ uses a rod shifted 020, guys. At least my Passat doner did. The TDI tranny was a cable-shift 02A. VERY different.
Post by: MJF on January 29, 2009, 07:30:22 am
Quote from: "stewardc"
It´s not from factory.
Post by: jtanguay on January 29, 2009, 09:54:50 am
i know someone with a cable shift '93 passat with a 1.9 AAZ.  he sold it to Giles.  He then installed the TDI box.  maybe some came with it and some didn't?  regardless, the whole shifter assembly can be taken out and swapped either way (to cable or to rod, or you can pony up and install a cable shift if not)
Post by: zukgod1 on January 29, 2009, 10:32:26 am
Cable shift is highly superior.
The transmissions are tougher as well.
Post by: MJF on January 29, 2009, 11:15:45 am
You can check from etka, Passat never had 020. Even 1,6 carb had 02A :)  Everything can be installed afterwards, that can explain stewardc´s doner Passat
