Engine Specific Info and Questions => IDI Engine => Topic started by: Busdriver on July 27, 2005, 04:41:18 am
Title: Vanagon Trouble
Post by: Busdriver on July 27, 2005, 04:41:18 am
I installed an AAZ 1.9TD in my 1990 gas powered vanagon. a few short thousand miles ago. Now it won’t start. I think that my major mistake was being hard headed about keeping the air conditioning. I have  manual steering  and didn’t want to convert (back) to power steering so I rigged me up some foolish home made  idler pulley arrangement so that I could have my diesel and air conditioning too.  The turn-key diesel had a serpentine belt that drove the alternator and water pump. It also had an extra v-belt pulley on the crank.
To get the air-conditioning to work, a larger size serpentine belt was used to drive the AC compressor and alternator, while a v-belt is used to drive the water pump and  power steering pump. Not having (or wanting) power steering I rigged up an idler pulley in place of the power steering pump tension the v-belt.  The idler pulley was tensioned with a sliding bracket connected to bolt holes on the (fixed mounted) AC compressor.
The AC compressor was off Volvo and had the right serpentine belt pulley in the right location and bolted right up to the VW engine bracket.  The home brew idler pulley is the only place I got weird.
Anyway it ran well and kept cool for a thousand miles. Then one of the two bolts holding the  AC compressor to the engine bracket loosened itself and fell off on the road somewhere, and the AC compressor was pulled out of alignment slightly by my idler pulley arrangement.   The serpentine belt got semi-shredded (two out of the original six ribs were still spinning the alternator, and the water pump pulley v-belt was slipping badly.  I noticed all this after I parked it, and  I could not re-start it.
I moved the AC compressor out of the way, installed the smaller serpentine belt which runs the water pump and alternator, and charged the battery, but it still turns over slow and doesn’t start.  So I did my first ever compression test on a diesel.  Whe I had the injectors out, I observed that all four glow plugs were lighting up. The car has been sitting for a few months now, and of course the engine isn’t warmed  up because it doesn’t start, and the starter doesn’t turn it over very fast, so I am not too horrified by the results, all four cylinders were between 410 and 420.  Maybe  the compression would have been higher if it the engine were warm, or if I could get it to turn faster, but it seems to me dragging. The ground cable on the battery gets hot to the touch when I try to start it.
So I look at the fuel.  Dirty, surprisingly disgustingly dirty. And water too! So  I change the fuel filter and prime and bleed and attempt to run it from a 5 gallon can of clean diesel fuel, bypassing the fuel tank entirely. Still won’t start.
What do you think?  Do I have enough compression? Maybe I didn’t get all the air out of the fuel lines, but I am using an electric fuel pump as an assist and the  5 gallon fuel can is above  (uphill, gravity-wise ) of the injection pump.  Should the negative post of the battery be getting hot?
Post by: VWRacer on July 27, 2005, 06:19:17 am
Since this is a troubleshooting issue and you have cross-posted to that forum, maybe this thread should be deleted.
Post by: Busdriver on July 27, 2005, 06:37:52 am
Thank you for the helpful suggestion.
