Engine Specific Info and Questions => IDI Engine => Topic started by: Dirtrag2 on December 29, 2008, 12:57:36 pm
I'll be looking for an IC for my diesel Fox projekt and was wondering if i'd be best off with an air cooled FMIC or with a liquid cooled IC. My thoughts are that a liquid cooled IC could be routed to rad for street use and also to a seperate ice water container for the drag strip. any ideas??
To the radiator?
I think I would just do an air to air and be done with it.
If your set on a air to water then do a separate system. The water in the rad can exceed 180 deg. Your already starting with hot air at that point.
Hmmm, I hadn't thought of high temp from rad :oops: running a complete system may be tedious but from all the info i've gathered the benefits seem to outweigh the grief. has anyone here ever run such a system?
I'm doing air to air with the possibity of a water sprayer via second windshield washer fluid container/pump and sprayer :P with a switch/relay set up in the dash. Need to pass a ricer who's pissing you off, flick on the water sprayer, the water meth injection, the nos, the propane and off you go. Am i the only on who has realized why there are so many empty switch spots on the dash of mk2s?
Complete swap sort of deal.
I'm not too keen on keeping compressed gas on board to release compressed gas to get that nice frosty effect on the IC.
