Engine Specific Info and Questions => IDI Engine => Topic started by: molgrips on November 02, 2008, 08:18:29 am
Title: The merits of proper tools
Post by: molgrips on November 02, 2008, 08:18:29 am
I tried setting the injection timing a while ago, but I didn't have the screw-in adapter so I used a magnetic clamp stand like you'd use in a metal workshop.  It sort of worked, so I thought.  The car ran fine except it's been a bit buzzy and noisy at speed, and with the cold start handle out it sounded quite rattly.  I thought that was just how it was with the handle out..
Well, I just checked it now, and it was almost 1.0mm, and I thought I'd set it to a conservative 0.92mm!  I put it back to 0.94mm based on people's views on here, and the fact I'm running veg - albeit thinned.
The car's way smoother all through the rev range, and nicer to drive in general.  For some reason I can now feel the governer coming in at about 3.5-4rpm - time for another mod I think.
The thing is, I'm after smoothness in driving and economy rather than power (yes, I know I'm an interloper on this forum) so would it benefit from more retarding perhaps?  It's still not totally smooth at speed.
Post by: jackbombay on November 02, 2008, 12:07:17 pm
retarding will make it less efficient, advancing timing will help MPG, to a point.
Post by: molgrips on November 02, 2008, 01:15:44 pm
I suspect my injectors though - if they are weak that'll have an advancing effect, right?  Must get them rebuilt.
Post by: jackbombay on November 02, 2008, 09:28:41 pm
I think so, but a worn pump will have a retarding effect so it could be a wash.
