Engine Specific Info and Questions => IDI Engine => Topic started by: allsierra123 on October 15, 2008, 04:40:02 pm
Title: Kind of a Dumb Question
Post by: allsierra123 on October 15, 2008, 04:40:02 pm
What is the little canister On the passeger side of the aaz block. That has a shaft going into the block it self and A vacuum line coming off of it with a check valve on it. And next question do I need it and How do I go about getting rid of it?
Post by: 53 willys on October 15, 2008, 06:32:03 pm
that's your vacuum pump....why do you wanna ditch it?
Post by: allsierra123 on October 15, 2008, 06:38:23 pm
Well Im not sure I actually need it. Havent found a use for it yet. Maybe im missing something That needs to be hooked up to it.
Post by: Vincent Waldon on October 15, 2008, 06:41:43 pm
It *should* be connected to your brake booster....  :shock:
Post by: allsierra123 on October 15, 2008, 06:47:28 pm
HAHA I knew there was something I was missing. LOL.  Thanks for reminding me It would have made stopping much harder.
Post by: 53 willys on October 15, 2008, 06:51:29 pm
I'm no vanagon expert but it should control your heater vent controls too??
and cruise control if vanagons have that?
put a ABS set-up in it and you wont need any Vacuum :lol:
the only thing my GLI needs is vacuum for the cruise and heater controls....
Post by: allsierra123 on October 15, 2008, 07:07:34 pm
No Abs Heat Is totally stand alone All I would have is the Power breaks. I do remember Disconnecting that line now. Thanks for reminding me. What is the check valve for?
