Engine Specific Info and Questions => IDI Engine => Topic started by: garagebandboy on October 10, 2008, 06:17:33 pm
Title: return line
Post by: garagebandboy on October 10, 2008, 06:17:33 pm
i put clear fuel line between the injectors and i noticed lots of air bubbles in them. would it be okay to plumb the return line through the injectors?
Title: return line
Post by: autoholic on October 10, 2008, 06:21:49 pm
I think it would be too restrictive to send all return fuel through the injectors. Interesting thought though.
Title: return line
Post by: garagebandboy on October 11, 2008, 01:42:04 pm
what if i made it so it would flow out of both the return line and the injectors. instead of blocked off at the last injector?
Title: return line
Post by: jtanguay on October 11, 2008, 08:35:32 pm
Quote from: "garagebandboy"
sounds like a bit more lines than you'd want to me.  are you trying to achieve no bubbles or something???  i dont think that this will fix that problem.  how does it run?
Title: return line
Post by: Jet A on October 11, 2008, 09:44:35 pm
not that you need a reason, but why?
Title: return line
Post by: garagebandboy on October 12, 2008, 12:02:33 am
just because i'm trying to get from 0-60 faster then 25 sec.
Title: return line
Post by: shegel on October 12, 2008, 09:13:18 am
giles pump .....or impossible....or just go down a big hill
Title: return line
Post by: garagebandboy on October 14, 2008, 08:53:40 pm
how much does it cost? i'm thinking of turbocharging
