Engine Specific Info and Questions => IDI Engine => Topic started by: burn_your_money on September 08, 2008, 04:33:01 pm
Title: Yep, definitely a monday
Post by: burn_your_money on September 08, 2008, 04:33:01 pm
Giles: What are you working on today Tyler?
Tyler: Umm... I think I was working on ***********'s super pump
Giles: OK, carry on then
So I crack it open and hurray, presents
(http://img.photobucket.com/albums/v603/burnyourmoney/P9070229.jpg)
That's the advance spring
(http://img.photobucket.com/albums/v603/burnyourmoney/P9070224.jpg)
And this is what the rest of it looks like
Looks like it has been at the bottom of the Atlantic for the past decade.
I spent all day cleaning it in order to properly assess it, and yep, it's junk. :roll:
Post by: blkboostedtruck on September 08, 2008, 04:44:27 pm
i see that boost pins good ! good thing you sent that pump back to me!
you know the one i sent and you sent back!
 i forgot i rapped it for the boost pin for my 1.9  so i could use another pin!
got a extra one you can send?
Duane
Post by: burn_your_money on September 08, 2008, 04:49:38 pm
Yes very good I sent it back to you. Someone would not have been happy. I don't have any spare pins.
Post by: ezekiel on September 08, 2008, 06:28:08 pm
wow
talk about knackered
Post by: gigaz2 on September 08, 2008, 06:33:07 pm
isn't that the lime green spring everybody is after?  :lol:  :lol:
why was a junk pump been spray painted to look "new"?
Post by: autoholic on September 08, 2008, 06:34:40 pm
Yea, that is ugly.
I wasted an entire Saturday going through a friends pump too, except this one was "newly rebuilt" Turns out they left two washers just laying in it which got all ground up. I should mention who "they" are but I am still trying to get a hold of them for a new pump.
Post by: burn_your_money on September 08, 2008, 07:03:20 pm
wash, sandblast, strip. That is why the outsides are snazzy looking
Post by: zukgod1 on September 09, 2008, 07:09:52 am
That's just nasty right there..
I hope I don't come across one of those..
Post by: Turbinepowered on September 09, 2008, 03:30:09 pm
What is all that crap? :shock:
Post by: BioDieselVW on September 09, 2008, 04:19:35 pm
Rumor has It that Im the Lucky Owner.
Post by: theman53 on September 09, 2008, 05:07:19 pm
what is Junk? Do you mean you cant rebuild it or that there just isn't any good parts and it will all have to be replaced? I am asking because mine that I want to send up to you guys to build probably looks something like that inside.
Post by: burn_your_money on September 09, 2008, 06:32:28 pm
A lot of the expensive parts are no good.
Driveshaft
transfer pump
rollers
cam plate
etc
Even the head and rotor is questionable on this one, but it would need to be tested on the test bench.
It would be cheaper to have a different core provided.
The pump was siezed solid when we got it.
Has yours siezed?
If you think yours is this bad, call Giles first and ask him what he suggests. He might get you to do some "pre-surgery" to assess it, I don't know.
Post by: blkboostedtruck on September 09, 2008, 06:42:39 pm
Quote from: "BioDieselVW"
how many hurricanes has that been through?
Duane
Post by: burn_your_money on September 09, 2008, 06:47:05 pm
The funny this is, I sold it to him 4 months ago, and it came from a car that had been running about 1 month before that :?
Actually it's not funny, because now I'm going to be out some money.
Post by: theman53 on September 09, 2008, 07:50:52 pm
My pump turns and had diesel in it. I will let you guys up there in wonderland know the status and will call as soon as I have my engine put together...I am selling a 1.6L car to pay for this project :cry:
thanks and hopefully I will not have any problems with this. Lucas ><>
Post by: burn_your_money on September 09, 2008, 07:59:56 pm
If it still turns over it's problaby fine. Even though this one looked as bad as it did Giles still had me clean it because it might have been savable. I doubt yours is anything near this bad.
Post by: zozep on September 10, 2008, 08:56:22 am
was mine this bad?
Post by: burn_your_money on September 10, 2008, 09:55:33 am
Quote from: "zozep"
was mine this bad?
No. Yours was a rusty POS on the outside but the inards were clean
Post by: jtanguay on September 10, 2008, 11:27:20 am
i think this is a good example of why people should not store their pumps dry
i suppose filling it with something like ATF for extended periods (or even just a few months in some cases), with ALL ports carefully blocked off, should suffice right???  8)
i dont think many people realize that diesel does break down...
Post by: Smokey Eddy on September 10, 2008, 02:59:31 pm
ATF will last a very long time.
You use the same priers as me Tyler :) and that weird  black handled one came out of my donut in the trunk. It has a use?
Post by: burn_your_money on September 10, 2008, 06:32:17 pm
I love my black screwdrivers from MK2s. I have 2 of them. One in Philips mode, one in Standard mode.
Yes if this pump had beren stored full of any fluid (Except water) it would definitly not have been in this state.
The pump was in florida so the humidity is probably what did it in so fast.
Post by: Vincent Waldon on September 10, 2008, 07:03:10 pm
I'm thinkin' those pliers are Canadian Tire's finest ??!!!   :wink:
Post by: burn_your_money on September 10, 2008, 07:05:45 pm
absolutly. Only the best :D
Post by: burn_your_money on September 10, 2008, 07:08:23 pm
I actually had to clean a pump that has been using biodiesel today. I had to acid dip it to get the biodiesel residue off the parts, and even then it only softened it and I had to brush it off.
I'll ask Giles what he recomends. I know all of our core pumps on the shelves are stored dry and they are fine on the inside (cracked 2 open today). Basically keep them away from moisture and they should be ok
Post by: Smokey Eddy on September 11, 2008, 12:09:52 pm
would super low viscosity oil be a good choice?
Some nice synthetic or something.
Just a thought though
Any residual oil wouldn't matter either... diesel is after all basically oil.
Post by: gigaz2 on September 11, 2008, 01:22:32 pm
I got a set of injectors that were used on biodiesel and SVO, they reek!! plus, I had a hard time getting them clean.
moiture+(diesel, svo or biodiesel)=trouble
