Engine Specific Info and Questions => IDI Engine => Topic started by: catlin_cava on August 26, 2008, 07:14:55 pm
The motor will turn over but won't fire up...If I hook the GP directly to the batt for 30 seconds, The Motor will start...When the motor came out of the donor it was running well...Please help
um... you just need to get the GP wiring hooked up then :wink:
most likely the engine is just tired. normally they should fire after about a few seconds of cranking on a warm day.
Could have a bad fuse or relay.
