Engine Specific Info and Questions => IDI Engine => Topic started by: Torchd on July 19, 2008, 06:40:53 am
Title: How to PORT and POLISH
Post by: Torchd on July 19, 2008, 06:40:53 am
I bought a rebuilt head for the 1.9 AAZ which i havn't installed so far....
It is assembled and i'd like to port and polish it before the install..
How do i port and polish?? and what things will i need for the job?  will i have to get new oil seals or anything that cannot be reinstalled once removed?
Thanks!!
Post by: g-spec on July 19, 2008, 08:56:21 am
The way I did the head on my car is gasket matched. which means that you take the intake and exhaust gasket place it one the head and mark a circle on the inside of the gasket. Then I removed all extra material and smoothed it all the way to the valve seat. I also removed all the rough surfaces in the ports. The intake ports I left rougher...and the exhaust I polished smooth.
You will need some kind of rotary tool with all kinds of aluminum cutting and sanding bits. You will also need a valve spring compressor.
I hope that helps a little.
Cheers, Michal
Post by: VW_Commuter on July 19, 2008, 10:19:58 am
Follow this google link (http://www.google.com/search?hl=en&q=how+to+port+and+polish+a+head) and you will find many hits on how to port and polish a head.
Post by: 79rabbit4dr on July 19, 2008, 10:42:20 am
I always thought about using one of those cylinder honing ball things... if you could find a small enough one... i think that would work perfectly!
This is what I'm talking about, there's probably better articles/pictures, but this gives you an idea:
http://www.mrotoday.com/mro/archives/Uptime/08JJ_FlexibleCylinderHoning.htm
Post by: chrisrandle1 on July 20, 2008, 05:09:49 am
Has anyone done the port and polish by its self, meaning no other mods at the same time.  I was wondering what kind of gains I can expect from porting and polishing.
Post by: hatemi on July 20, 2008, 05:56:13 am
One tip. Dont port match the exhaust. Or if you want to then fill the exhaust manifold and port that but dont make the exhaust exit any larger than it already is. Youll only kill the flow with that. And the exhaust gasket hole is actually larger than the hole in the manifold so there woldnt even be any reason to use it as the model. You can however make the exhaust port alot larger inside the head and around the valve stem.
Post by: Pat Dolan on July 20, 2008, 06:40:47 am
Quote from: "chrisrandle1"
WWAAYYY back when A2 were current, we bought an NA car that had been butchered by an idiot shop, and put it back together.  It was otherwise dead stock, except for the port job.  Performance was almost TD level.  I wanted to put a nice exhaust system behind it, but it sold too quickly (and boy did I ever get a lot of tickets in it!).
Post by: Torchd on July 20, 2008, 08:11:45 am
Hayemi..... can you please clarify??  i didnt quite get you!
Post by: hatemi on July 20, 2008, 11:07:58 am
If you make the exit of the exhaust port as large as the gascet is then its larger than the hole in the exhaust manifold. And by making it larger you slow the gas velocity thus making the turbo spool up later and work more ineficently. And the restriction in the port is behind the seat and around the valvestem anyway so no point in touching that area. My previos TDI head was practically untuched around the gascket areas but made 100% better where it counts.
Post by: Torchd on July 20, 2008, 11:18:45 pm
So u mean i shud't port the exhausts exits in the head?
Post by: hatemi on July 21, 2008, 08:50:06 am
Yes. You will only kill the velocity of the gas and you dont want to do that.
Post by: vanagonturbo on July 21, 2008, 07:45:15 pm
Umm, if you port match the manifold too, then you have a result of great overall gains. I understand what you are saying about the gasses running into a wall if the exhaust manifold is not port matched too. I jsut spent 3 hours on my frankenmotor last weekend porting and polishing the exhaust ports. HUGE difference is area in the ports. Just gotta get the intakes done.
I do agree though, port matching the exhaust ports will not necessarily help. You need to do at least the inlet area of the exhaust manifold.
I wouldnt really worry about leaving the intake ports rough on a turbo engine, especially a Diesel. The turbulence caused by the roughness in the intake ports helps for better imulsification of the fuel when mixed with air. In the IDI application, the fuel is combusted in the swirl chamber so its not all that critical to have the intake ports rough.
Post by: hatemi on July 21, 2008, 10:40:06 pm
The only matching I would do would be done on the manifold side. You just DONT want to make the exhaust port on the head any larger than it already is. Smaler would propably work better!
If the exhaust manifold has a smaler hole than on the head(the gascket has alot larger hole than both) then by all means match it. If its larger then you either need to fill the gap by welding or just leave it be.
Post by: tylernt on July 21, 2008, 11:07:12 pm
You don't want to polish gasser intakes to a mirror finish because they need the turbulence to evenly mix the gasoline mist with the air. But on a diesel, polish that baby up. The swirl chamber gives you all the turbulence you need.
Post by: DieselKraut on July 22, 2008, 05:09:02 am
I believe hatmi is correct about loss of velocity when porting the exhaust. But I would think a light polish on a TD would help. But on a N/A I think porting and polish w/ port matching would be the best. Since your not needing the exhaust press for the turbo.
Post by: Torchd on July 22, 2008, 01:08:42 pm
Cooool!!
So how deep do i go with the intake ports on the head??  just 1-1.5 inches?? can't i go any deeper?
And how can i port match the manifolds (exhaust and inlet)  same 1-1.5 inches depth or can i port the whole length some how?
for polishing.. i can polish the whole length of the manifolds by using that flexible cable thingy.. rite?
Thanks!
Post by: 53 willys on August 11, 2008, 10:16:00 am
so I am thinking about porting and polishing my head...I just dont understand why you would not port the exhaust ports???
I can understand what you guys are saying to a point about velocity...but all the porting I hear about on big diesels(cummins) say the most important place to port is the exhaust side... really helps reduce EGT's
seems to me a good port on the exhaust and maybe a smaller exhaust tubing would be better??? 3" exhaust on a 4cyl diesel seems way to big to me...I bet if a guy had 3" exhaust system and went back to a 2.25 or 2.50 he would notice a real nice low end gain...
thoughts???
Post by: 53 willys on August 11, 2008, 07:04:28 pm
Quote from: "53 willys"
thoughts???
anybody???????
Post by: lord_verminaard on August 12, 2008, 06:22:43 am
You can port the exhaust, but the problem you may run into is making the ports on the head bigger than the ports on the exhaust manifold, which would be a big problem.  It's actually a little better on exhaust to have a "step" where the manifold is a tad bigger than the exhaust port to prevent pressure reversion.  But yes, I'm in the camp that the exhaust side (porting, and manifold) needs opened up much more, but to really take advantage of that, some manifold work and/or custom manifolds are needed and that is out of the realm of most of the people that want a slightly peppier car without a ton of effort.
Also, with exhaust tubing diameter, there is a popular belief that you need backpressure to make power and that by removing backpressure it kills low end torque.  This is so completely untrue- in a naturally aspirated car, there is a point in exhaust size where maximum gas velocity occurs- this is the point at maximum efficiency of gas flow which helps to scavenge the cylinders.  Going to a larger exhaust after that point will only slow down velocity which will hurt engine efficiency.  Backpressure is NEVER a good thing and by increasing exhaust velocity you are actually eliminating as much backpressure as possible.
Turbo cars are different.  With a turbo, the restriction is the turbine itself- there is always a lot of backpressure in the exhaust manifold before the turbo- hence the main downfall of a turbocharged system.   You want the exhaust gasses to escape as fast as possible to keep stress off of the turbine and to encourage it to spool- therefore the general rule with a turbo is to make the exhaust as big as you can fit- exhaust gas velocity makes much less of a difference post-turbo, since there is no cylinder scavenging going on, but you can encourage exhaust velocity by making a tapered "cone" exiting the turbine; i.e. say your turbine outlet is 2" and you have a 2" pipe that gradually expands to a 3" pipe over a certain distance.  This has proven to increase turbine efficiency a small degree.  Theoretically, the best turbo exhaust system is the aforementioned "cone" out of the turbine that dumps directly out after that.  Sometimes you will see the NHRA sport-compact drag cars with systems very similar to that.
HTH,
Post by: hatemi on August 14, 2008, 02:00:34 pm
The real power is in the exhaust. But not the end part that mates to the manifold but in the head just after the valve. Try to get that part smoth and to the same size(flow area) as the end of the port is. You dont need to touch the side of the port that mates to the manifold. Its already large enough. Just make the inside as free flowing as the outlet is.
Post by: 53 willys on August 15, 2008, 10:12:21 am
thanks for the info guys...that does clear it up a little better for me 8)
I am just going to do a real light port and polish on my head...nothing crazy.
thanks again for the info.
