Engine Specific Info and Questions => IDI Engine => Topic started by: iltisdiesel on March 02, 2008, 03:10:02 am
Title: New to diesel engines and have a question about 1.9 td
Post by: iltisdiesel on March 02, 2008, 03:10:02 am
I have a 1.9 td that I was give by a buddy down the road. He said it ran
when he put it a way. When i was cleaning it up I turned the fly wheel
and found it to turn with some resistance but i thought with the high compresion of the diesel that it would be very dificult to turn over, is that the case or is it as easy as a gas engine to turn by hand?
Post by: Patrick on March 02, 2008, 04:40:12 am
It should be harder to turn than a gas engine. Spec for compressoin is at least 377 psi (19.5 to 1 compression) Last time I checked mine has about 480 psi across all 4 holes. Gas is probably 150 psi? 1.6 diesels have even more squeeze at 23.5 to 1.
If you think it's junk though and want me to take it off your hands..... :lol:  :wink:
Post by: iltisdiesel on March 02, 2008, 05:38:45 am
I heard it running a before he pulled about a year ago but was surprised how easy I could turn it over by hand. I was thinking that maybe i should send it to be overhauled before I put it in my Iltis. Hate to do all that work and find out that I should have rebuilt it before putting it in.
Post by: hillfolk'r on March 02, 2008, 06:19:29 am
can you bolt a tranny to it,and test fire it on the floor before installing?
i know,thats alotta work too,but better than having to remove it after installing it
Post by: Patrick on March 02, 2008, 06:57:30 am
I'm with him, see if you can test fire it. Should be fine if it ran when pulled..........
Post by: iltisdiesel on March 02, 2008, 07:02:09 am
No I don't have a spare tranny wish I did. This is going to replace my 1.7 gas engine so i have alot of work to do to put it in that's why i would like to know if it's good but I do know it was running when removed.
Post by: jimfoo on March 02, 2008, 07:59:28 am
When I got my 1.9 that had been sitting for a while, I could turn it over with a ratchet. I think with the lack of oil on the rings, compression could easily slip by as it was way harder after I finally started it.
Post by: flash319 on March 03, 2008, 06:58:50 am
Also the valves probebly have some corrosion on them from sitting so they are not sealing very good until it gets running again.
