Engine Specific Info and Questions => IDI Engine => Topic started by: moTthediesel on January 07, 2008, 11:52:08 am
I'm rebuilding an '85 Quantum engine now for my 356TD project. and I want to put in a new oil pump while I'm at it.
This engine is a solid lifter type, would it be worth while to install a newer style oil pump from a hyd. lifter engine -- as I've heard that they are larger capacity? It also seems that the newer Meyle pump is actually about $20 cheaper :?:
moT
im currious about this question also....
Are the pumps the same or?
Later pumps are 36mm and will bolt right up. I think it's a good idea especially on TD motors.
Andrew
Hell ya!!
Get the newer 36mm pump for sure.
Andrew
You just need new bolts because the 36mm pump is taller
What engines had the 36mm pump? I'm ordering online, and I know they were an OEM application. Just want to make sure I'm getting the right one.
Thanks.
Why not just get it from myke_w? He sells the right ones at a good price.
92 TDs defiantly had them but I'm not sure of the exact range
I agree, check with myke_w
I would, for sure, but I'm ordering a few hundred $$$ of engine parts for a rebuild from autohausaz, not just an oil pump. I'm getting free shipping. Their parts are German unless noted, and the prices are fantastic. I'm sure mike_w is a great guy to do business with, though. Does he sell everything to rebuild an engine? How would I get in contact with him? I wouldn't mind giving him a shot.
I bought all my parts to rebuild my TD from Myke W.
36mm pump, new KB pistons, Rod bearings, main bearings, int shaft bearings, head gasket & bolts, gasket/seal set, mounts, injector nozzles, and some antifreeze hoses.
He gave fast service and every part was excellent quality. All was German OEM I think except for the Glyco main bearings which If I remember right were Made in USA.
