Engine Specific Info and Questions => IDI Engine => Topic started by: boostaholic on January 02, 2008, 07:49:20 am
so i want to swap a TD into my N/A diesel coupe.. and i am curious any years better then others to look at for the 1.6 td? thanks
The one with the T3 on the back,JR engine code i think :wink:
Bert
i don't believe the engine code has much to do with what turbo it has, but i could be wrong. the only real differences are the which turbo and whether its solid lifter or hydro lifter.
so a 1984 would have? solid lifters?
Probably the last years of production would be the most reliable ie 91-92. The lowest mileage is good too, just so everything is not worn out. You can re-machine everything of course but it gets pricy. I find it hard to beat the stock assembly from the factory, it takes a very good diesel specialist machine shop to duplicate the reliability of a factory engine. Speaking as one who has blown up my share of engines and built quite a few. Cheers Dan
I'm afraid of 92 TDs in the 200-300k range because I've heard that they have bad piston rings. I've taken 2 apart to confirm this. It's just a phobia though and most are probably fine
