Engine Specific Info and Questions => IDI Engine => Topic started by: vw-uziel on December 19, 2007, 01:54:17 am
Hi all,
Ok, I got all the parts (I hope) to turbo my 1.6d. Now, the block is a NA1.6 with NA 1.6 pistons. I don't want to go over normal boost 10PSI?. Will the pistons be ok?
I am new to this all so please excuse me for dumb questions.
(http://img126.imageshack.us/img126/4166/dyno16gtdvy1.jpg)
JK with all external stuff from a gtd+external oil cooler and front mount intercooler.
just installed metal gasket and merc. injectors and its holding fine for now. :wink:
I've looked into this myself. Where do you connect oil feed from the motor? I assume you drill a hole into the oil pan for the return.
I would like to know the(sweet spot) to drill/tap for an line.If anyones got pics that would be great
most people us the sandwich deal from a volvo, it goes between the filter and the filter flange.
the real sweet spot is in the block! drill and tap the block for the oil return line from the Turbo! but there are all sorts of different routs you can go!
thanks Duane
Not to highjack, but:
Is the exhaust manifold the same height as the NA manifold so you can just bolt (Spring?) up the same exhaust? I am considering doing a complete TD swap in my NA Golf and was wondering I would have to redo the exhaust.
not same height.
I think it's close enough that it doesn't matter. I swapped a 1.6 NA into a mk2 that had a 1.6 TD and a 1.9 TD in it over the course of it's life. The downpipe didn't have to be changed
Thanks. [END OF HIJACK]
I was thinking MKI. Its off by about 2-3 inches IIRC. I know I had to section the downpipe on my last Scirocco TD just to make sure the rest of the exhaust was straight. not sure on the MKII but I know its a different length there too. You could run into steering rack rubbage...
To the OP, I think you would be just fine with what you have. The amount of boost is pretty much irrelevant as more boost lowers EGTs on the Diesel which is the opposite of a gasser. Make sure you put a preturbo EGT probe in with a pyrometer to monitor the temps. That way you can KNOW if you are doing damage to the engine and tune accordingly.
[runs an 11mm NA engine @23 PSI]
Did you say diesel Scirocco? HMMMM. what about a TDI-M in a Scirocco? :idea:
Sorry for the compression ignition interjection. I haven't been here for a while and the Scirocco diesel thing caught my interest in a big way. :o
Thanks for the :idea: :D
Hi All...
This past weekend I put on the turbo for my NA Diesel. One question, it smokes like crazy...black smoke...is this normal?
201.9 ft/lbs torque? wow nice!
i guesse when doing the governor mod it should kick more torque.
luckly it only comes at high rpm,my clutch says thanks :lol:
