Engine Specific Info and Questions => IDI Engine => Topic started by: Riverfurm on November 17, 2007, 11:46:26 am
Title: To soot or not to soot
Post by: Riverfurm on November 17, 2007, 11:46:26 am
Got about 1000mile on my 1.6 turbo motor. It has a Giles pump set at .95, 3" SS passenger downpipe, 3" ex. with a flowmaster and runnin 20 psi max on boost.  It's in an 86 Golf two door.
The back of the car gets sooted up after about a week. I played with the max fuel screw. It seem no soot no power. The max EGT I get is about 1150F under an hard pull with 20 psi boost allot of smoke.
Is this about normal? My fuel milages seems good (38-40 MPG). Full boost is about 3800-4500 rpms. I also notice when the engine is hot the turbo woks better.
So can I make this engine not soot up my hatch back, but still keep my new found power?
Thanks for any help.
Post by: Black Smokin' Diesel on November 17, 2007, 11:51:13 am
Turn down exhaust tip. I wouldn't reduce power to keep soot off my rear end.
Post by: gnavs on November 17, 2007, 11:57:53 am
x2
the back of my jetta gets sooty, but i have straight exhaust tips.
Post by: jtanguay on November 17, 2007, 12:24:12 pm
the turbo likes the hot oil because its thinner.  if you want your turbo to last, don't beat on it when the engine is cold.  i try to stay out of 5 psi range until the engine hits 1/4 on the gauge.
Post by: TD_Bunny on November 17, 2007, 10:12:22 pm
hey do you have a IC in your Golf with those EGT?
Post by: subsonic on November 18, 2007, 03:59:49 pm
What they said, slight turn down on the tip.  If you are getting the soot you have room(fuel) for more boost.  IC and try and boost a few more pounds.
Post by: stewardc on November 19, 2007, 03:19:45 am
Get some synthetic oil into that engine once it's properly broken in and the turbo will really love you.
Post by: Riverfurm on December 01, 2007, 06:52:18 am
Quote from: "TD_Bunny"
No intercooler
