Author Topic: How to store an IP off car?  (Read 3979 times)
June 11, 2007, 09:57:58 am
ricosuave
  • 244
« on: June 11, 2007, 09:57:58 am »
I've heard keeping it submerged in diesel, others just have it on a shelf, open to atmosphere...
Whats the best way to store it?
Now: 00 2dr Golf TDI, 03 Jetta Wagon TDI, 02 2500HD Duramax - :)
Then: 69 SC Transporter, 84 Rabbit GTI, 87 Fox GL, 91 Golf IDI, 96 Passat Wagon TDI, 97 Jetta IDI - :(
"Everything I save by driving diesel I put back due to poor German engineering and crappy Mexican workmanship!"   :P
Reply #1June 11, 2007, 11:43:00 am
saurkraut
  • 904
« Reply #1 on: June 11, 2007, 11:43:00 am »
If you've ever seen a new pump, ever port is covered by a plastic cover of some sort.
Leaving them open to the air is probably inviting potentiol problems.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2June 11, 2007, 05:23:26 pm
Black Smokin' Diesel
  • 656
« Reply #2 on: June 11, 2007, 05:23:26 pm »
Fill it with diesel and plug every hole open to atmosphere. Should be enough.
91 Passat syncro 1.8T swapped.
Reply #3June 11, 2007, 08:50:25 pm
  • 3255
    • My collection of HOWTOs
« Reply #3 on: June 11, 2007, 08:50:25 pm »
Yup, diesel degrades over time (which is why anyone with a backup diesel generator runs the fuel thru or drains it on a regular basis).
Machinists I know tend to stay away from 3 in1 (evidently it is quite acidic due in part to the citronella added for its cleaning properties and tends to varnish over in time) so I'd probably avoid it... sewing machine oil is a great suggestion.  I suspect a good quality 10W30 would work well too.  Machine tool oil is what machine parts are archived in.. dunno how much a pint or more would cost.  Or gun oil ??
Reply #4June 28, 2007, 07:10:51 pm
ricosuave
  • 244
« Reply #4 on: June 28, 2007, 07:10:51 pm »
so, what about one that has been emptied and open to the air for ~1yr?  how do you all think that would fare?
Reply #5June 28, 2007, 07:55:04 pm
« Reply #5 on: June 28, 2007, 07:55:04 pm »
I'd imagine it will leak. You may be able to run some seal conditioner through it first. I'd fill it and let it sit for a while (overnight)  before trying to turn it over
Reply #6August 14, 2007, 07:20:10 am
wikdslo
  • 103
« Reply #6 on: August 14, 2007, 07:20:10 am »
What about if its been off the car for about 2 ~ 3 weeks?
Reply #7August 14, 2007, 05:35:50 pm
« Reply #7 on: August 14, 2007, 05:35:50 pm »
probably fine but there are alot of variables
Reply #8August 15, 2007, 04:56:35 am
madmedix
  • 204
« Reply #8 on: August 15, 2007, 04:56:35 am »
Interesting stuff, keep us posted. I got a spare 1.6 TD engine with the Jetta I just picked up and its IP & turbo still attached. God only knows when the last time it turned a rev on its own. Sitting on an engine stand right now and I'm toying with the idea of tearing it down or selling it..
'90 TD Jetta
