Engine Specific Info and Questions > IDI Engine
Awakened from a long slumber....
RabbitJockey:
i agree with fatmobile, my first guess would be bad turbo seals on the exhaust side.
marvel mystery is a great additive, i'd recommend even putting some of it in your fuel.
how wet is the exhaust and are you sure its oil? cause water is a natural byproduct of combustion, and diesel smell bad either way
westcoaster:
It was pretty wet at the tip of the tail pipe, almost dripping.
I suppose it could have been condensation. There was no particular odour to the liquid. It could have been purging the residual 6 year old diesel out of the system and somehow excessive moisture was produced.
It is running clean(er) now.
Sat and cooled over night and the next day things had cleaned up considerably.
I had also run it to the governor limit a couple times for a few seconds the evening it was having its issues.
Some MMO might not be a bad idea...
With the motor doing better I have shifted my focus to the death wobble this thing has now developed.
ORCoaster:
I second that MMO addition and if it is behaving itself for now drive it a bit and get it warm enough to dry out the exhaust system. When they get wet and are all dingy inside, they can have a black wet look out the tailpipe.
Death Wobble?? Maybe this isn't the time to dry out the exhaust with a good long ride.
westcoaster:
Yup, Death Wobble...
Imagine the front wheel on a shopping cart wobbling back and forth but instead on the front wheels of a vehicle.
Funny enough, in my search for the cure, I found new Ford Superduty trucks also seem to have this affliction....
I think I was able to "patch up" the death wobble by removing the front leaf spring bushings and rotating them 180* in the springs and frame.
The rubber had sagged where the bolt wasn't in the centre of the bushing any longer.
Tightened up the spring shackles and took it for a run. Seems to be "better" for the moment.
ORCoaster:
Leaf springs on the front? I am sure you meant wobbly wheels on the back. Otherwise, you are driving something that VW didn't make or driving in reverse.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
