Author Topic: 1.6IDI Not Fully Rotating/Not Starting  (Read 31232 times)
February 22, 2024, 06:21:05 pm
Mohatanous
  • 16
« on: February 22, 2024, 06:21:05 pm »
Hello all!
I am new to the VW Diesel world and just picked up a 1983 Rabbit. The individual I got if from said that it had been running about a year ago but tried to crank it and it wouldn't start. Upon having it looked at they saw that the air filter had been chewed on by mice and didn't even try to start it afterward in fear of damaging things. I bought it and got it home and before cranking it I put a socket on the crank pulley to make sure the motor would rotate freely before trying to start it. It makes it nearly one whole rotation then stops and will not budge. It does this in both directions and stops in the same spot. I am not familiar with these engines yet, and am curious as to what I may be getting myself into and what the best course of action may be. Any advice would be great!
The person before me had been running it on vegetable oil at one point, and then apparently a fuel valve had went bad resulting in diesel pumping back into the vegetable oil tank, so I believe that's why they originally parked it. It seems to me that perhaps somebody tried to start it with ether or something and it skipped time, causing catastrophe. I'm not sure though, so i am asking the professionals. Thank you in advance!
Reply #1February 22, 2024, 07:10:02 pm
Re: 1.6IDI Not Fully Rotating/Not Starting
« Reply #1 on: February 22, 2024, 07:10:02 pm »
DO NOT TRY YOUR STARTER ON THIS YET!!!
Get it checked for timing, that means you need to pull the valve cover and align the cams if you can.  Lobes of the first or last cylinder, #s 1 and 4 should be in the horizontal position.  The IP plug should be able to get in the timing hole.  I use a 3/4 inch carriage bolt for that pin.  The plastic plug on the end of the engine needs to come off so you can see the timing mark for TDC.
Watch some U Tube videos, and GET A BENTLEY MANUAL, it will be used well in the future.  But if this engine has jumped time and you hammered that valve with the piston it will be toast.  It may already be that.  IF not the clearance between the valve stem and the cam follower will be off.  Measure that if you can.
Don't want to alarm you but you are wading in potential doo doo here.  So many times I have read or heard of valves kissing the piston because of a poor timing belt job and it just shouldn't happen.  If the timing is off you will need to loosen the cam nut and get the pulley to spin freely.  Tapping it with a punch from the back to the front is normally the best way to do that.  The shaft is beveled with no keyway to keep it in place.
IF the pulley isn't free when you go to put the belt on if replacing it you can't line it up right and will fight forever trying to do so.  Moving the pulley with the IP solid and the crank at TDC is what makes it all go smoothly.  Then when tightening the belt with the tensioner you will see it move slightly as well.
Best of luck,  Not a good beginner story but you can keep out of trouble by making sure it rotates freely by hand four times around.  You were mechanic-smart trying to see if it would roll over by hand instead of hitting the starter.
Reply #2February 22, 2024, 08:04:13 pm
Mohatanous
  • 16
« Reply #2 on: February 22, 2024, 08:04:13 pm »
Thank you for the information! I had a feeling it wasn't a great sign and that a catastrophic timing issue may be the culprit. If it is a worst case scenario, what would the rebuild process look like, and would it even be worth it or should I look for a new engine? I appreciate the guidance!
Reply #3February 22, 2024, 08:44:37 pm
« Reply #3 on: February 22, 2024, 08:44:37 pm »
Say you time it up and the engine turns over by hand ok.  But it won't start or it smokes like a bad cigar once it gets running.
You might try a compression check on it before you even get to the START PHASE.  I say that because it would let you know if you have a cylinder with a valve problem.  Diesel engines need a different compression tester than you find at Autozone or ORielys for rent.  The good limit on a diesel cylinder would be around the 400 psi mark.  Gas engines are much lower.  They fire with spark plugs and diesel fire without, because of the higher PSI in the cylinder.  But you may already know that.
So say you do a check and one cylinder comes up in the upper 370-80 range.  Not good and suspect to me.  Time to pull the head.  Not a hard job but tools are needed that you may not have.  Older engines use torque to yield head bolts that would need to be replaced to get them to go back together.  A new head gasket is required, as well as coolant since you don't have any idea if it is good or not.  This is just for starters.
You might figure in a new timing belt and tensioner as those might be worn out and you will have them off.  A Bentley Manual will pay back dividends here doing this type of heavy-duty work.  To repair the head you will need new valves, easily found on Rock Auto or maybe Parts Place.  A new head is harder to find and probably would need a machine shop visit to make it right.  You will be pulling hoses off the engine and those if badly weathered, rat-chewed, or otherwise brittle will need to be replaced.
Getting a different engine is a crap shoot as well. You could buy one and unless the seller rebuilt it you will be looking at most of the same work but the engine will be out of the car.  Big deal, it is still money to be spent and then what do you do with the other engine?  How do you get it out?
I ran a diesel Rabbit on Veg oil for about a year and finally just quit doing it as the price for diesel dropped back down to a reasonable level.  With diesel up to that high level again it might be worth it to you to find a seller of processed WVO and get your system to work properly.  They can be a pain to maintain, and poor installation only equals poor performance.  I had mine dialed in pretty nicely and still gave up using it as diesel prices dropped.
I pulled all that stuff and it is in my shed now.  I sold the rabbit without it and I likely won't put it on the pickup I now own.  I would not gain any savings from doing so and only lose time working on it when I should be doing bodywork instead.
I have done several head/gasket rebuilds on the VWs I have owned but I am mechanically inclined and know what I am doing with the 1.6 engine.  It may be better if you are not to shop around for a good diesel mechanic and get a price from them.  Labor is super expensive these days for anything from burgers to buildings so I hope you got the car cheaply.
Later
Reply #4February 22, 2024, 08:56:45 pm
Mohatanous
  • 16
« Reply #4 on: February 22, 2024, 08:56:45 pm »
I'm mechanically inclined and have done a decent amount of work on gas motors, but not diesel's. If it's worth it to tear into it, I definitely will. I have the Bentley manual on the way! I appreciate the feedback and knowledge, and will be back with my findings when I tear into it. Thank you!
Reply #5February 23, 2024, 04:10:43 pm
  • 2932
« Reply #5 on: February 23, 2024, 04:10:43 pm »
 I think it's a good sign that it stops.
 When I broke a timing belt it just kept going around.
 Timing cover off first. Check the belt.
 Turn the engine to TDC and look through the timing hole in the trany. Compare it to the marks on the injection pump sprocket.
 Upgraded rubber valve cover gasket available. Comes from a MK3 gasser like a '94 2.0.
The valve cover studs need to be changed too.
Reply #6March 01, 2024, 05:49:24 pm
Mohatanous
  • 16
« Reply #6 on: March 01, 2024, 05:49:24 pm »
Update:
Upon digging a small amount more into the issue, I managed to get the camshaft to the position it is supposed to be in, but upon trying to turn the motor to the TDC mark on the flywheel view port, it will not go to the "0" mark, as that is where it is sticking. I'm suspecting there are bent valves and that the head now needs to come off, so that is my next step. What else should I check after pulling the head off? Does anybody have suggestions for what I should do if I get the head and valve train redone? Any recommendations would be great!
Thank in advance!
Reply #7March 01, 2024, 07:34:30 pm
Mohatanous
  • 16
« Reply #7 on: March 01, 2024, 07:34:30 pm »
Also, I'm not sure what this may mean, but when turning the camshaft it would not turn smoothly, but rather would move in sudden bursts, sort of like hitting compression. I'm not sure how to describe it, really. Thanks!
Reply #8March 02, 2024, 08:09:56 am
  • 2932
« Reply #8 on: March 02, 2024, 08:09:56 am »
  It might be a piece of nut shell in there, from the mice in the air filter.
 Or a dead mouse.
 A bent valve might show itself with the valve cover off, looking from the top.
Can you tell what cylinder it is? So you kinda know what valves to look at.
 1 and 4 TDC, or 2 and 3 180 from TDC, then what valves are open.
 Great idea to turn the engine by hand first.
Might want to try turning the cam too.
 Maybe pull the intake first so more stuff the mice left in there doesn't go into the engine. That won't cost anything, the intake gasket probably won't fall apart.
Reply #9March 02, 2024, 02:59:40 pm
« Reply #9 on: March 02, 2024, 02:59:40 pm »
If the mice left anything in the intake and it got pulled into or fell into the cylinders then You need to pull off the intake from the back of the engine and put a shop vac on each cylinder and rotate the crank back and forth to see if you can pull anything out of there.  You might pull the glow plugs or injectors off so you can get air in from the underside of the head and suck it off the valves.
Just my thought on it.  If you have one of those chip/sawdust collectors that go between the shop vac and the end of the hose use it.  That way you will be able to tell us what and how much crap you had in there messing with your start-up.
Reply #10March 03, 2024, 01:11:54 pm
Mohatanous
  • 16
« Reply #10 on: March 03, 2024, 01:11:54 pm »
After pulling the intake manifold off I was able to see inside a bit with a camera I have for peeking into small places like that. I was able to see all the intake valves moving freely, and all of the exhaust valves also appear to move freely and without sticking from the top when I turn the camshaft by hand. I was able to see the pistons coming up to the top of their rotations on each cylinder, but it still does not turn a full rotation. Pulling the injectors and glow plugs out and a combination of blowing air with a vacuum on the intake valves has not helped the issue, (I made sure that the intake valve for each cylinder was open while I had the vacuum on it to make sure any small crap may have been sucked out). I did not see any debris in the cylinders from my viewpoints. At this point I suppose my next step would be removing the head, although now I wonder if it could be something in the bottom end?
The saga continues!
Reply #11March 03, 2024, 01:36:22 pm
Mohatanous
  • 16
« Reply #11 on: March 03, 2024, 01:36:22 pm »
Also, when looking up parts for this, is this a reliable site?
https://www.partsplaceinc.com/amfinder/?find=1983-rabbit-1-6-d-153473991&p=2
I typically use Rock Auto for all my other things, but didn't know if this site would be decent for things Rock Auto may not have.
« Last Edit: March 03, 2024, 01:39:56 pm by Mohatanous »
Reply #12March 03, 2024, 07:01:30 pm
  • 2932
« Reply #12 on: March 03, 2024, 07:01:30 pm »
  Ahhh too bad some stuff didn't fly out and then it turns.
 No, I have had several friends who got burned by parts place.
 Try fcp euro or maybe autohaus AZ.
 Rock auto is a good place.
 Did you figure out what cylinder is stopping the piston?
 I wonder if the flywheel was put on wrong.
 Been a long time since I heard of someone changing the clutch and screwing that up.
 While the injectors are out see if you can confirm the TDC mark on the flywheel is at TDC.
 Maybe feel where the piston is as the valves are opening.
Reply #13March 04, 2024, 06:19:38 pm
« Reply #13 on: March 04, 2024, 06:19:38 pm »
Less of a problem to check the bottom side than to pull the head.  Loose crank caps perhaps.
Odd that you didn't suck anything out of the cylinders but then maybe the mice didn't get very far with their chewing and stashing work.
I'd pull the pan.
Reply #14March 07, 2024, 05:20:58 pm
Mohatanous
  • 16
« Reply #14 on: March 07, 2024, 05:20:58 pm »
Update:
Pulling the pan yielded no results other than finding a very dirty oil pan, which appears to have been leaking quite a bit. My next step is to pull the head and see what's going on. Maybe it swallowed a valve that I can't see or something else going on in the cylinders that I can't see. I may end up doing a rebuild of it at this point, it would help me really learn about the motor and I think it could be an adventure.
To be continued!
