Author Topic: 300 tdi pump rover pump  (Read 6471 times)
Reply #15January 19, 2014, 10:00:52 am
8v-of-fury!
Re: 300 tdi pump rover pump
« Reply #15 on: January 19, 2014, 10:00:52 am »
Riiiiight, and that was a much less stupid post CRSMP5? If one person causes you to leave this forum than so be it, its a free board. Sort-of.
Is that really ban worthy? Possibly, there were no repercussions that I could see.
I am pretty sure I read somewhere that the relaxed flyweights move the collar past where it would be for WOT, but I could be wrong.. I was wrong before :P.
Reply #16January 19, 2014, 10:27:09 am
« Reply #16 on: January 19, 2014, 10:27:09 am »
I assume that to be the only part of your post directed to me...
I think it really depends on the relaxed height of the idle spring and the position of the max fuel screw.
Reply #17January 21, 2014, 08:11:51 am
rodpaslow
  • 670
« Reply #17 on: January 21, 2014, 08:11:51 am »
The outside of this lever is shown on this picture, but the total movement of the lever might be 1/16-1/8" which moves that lever inside a very small amount.
[img]
Reply #18January 21, 2014, 08:12:21 am
rodpaslow
  • 670
« Reply #18 on: January 21, 2014, 08:12:21 am »
http://postimg.org/image/6p74y5guj/
The little two spring unit (1) moves the lever it's connected to (2) very little 1/16-1/8". the light springs take up the rest of the movement of the throttle.
So if it is to move the control lever inside the pump at startup/or when its off - the lever shown in the first picture is backwards, should the tip not be towards the back/ where the injector line connect; and not the snout or shaft side/ belt side of the pump?
Sorry for the problem, I should have taken pictures before pulling the top off.
« Last Edit: January 21, 2014, 08:23:45 am by rodpaslow »
Reply #19January 21, 2014, 08:36:38 am
« Reply #19 on: January 21, 2014, 08:36:38 am »
That first pic looks right.  It limits the max so the lever should be toward the snout in the at-rest position and move toward the injection lines to limit the fueling.
