Engine Specific Info and Questions > TDI - Pumpe Duese TDI Engines
CEL HELP Please BEW TDI
Powered by Spearco:
I have never changed out an injector but I just today did a camshaft, lifters and bearing shells an a '04 BEW TDI. It did start and run kind of choppy due to the wear on the cam and lifters, but after the new parts I needed to reset the injector lash to be shure it was in spec.
Its really easy. I roll over the engine to the injector that I'm adjusting so that the intake lobe on cam is pointing up and at the roller of the rocker. Loosen the jam nut, loosen the center 5mm allen a turn or two, then tighten it to a light seat then back it out 180*. Bentley says 225*. It runs better with 180*, tighten the jam nut and go to next cylinder. Just like adjusting valves on a Chevy SB.
Make sure that in Vag com, measuring blocks, group 4 channel 4. The torsional value is 0.0KW. Thats your timing. It might say the spec. is +/- 3, but 0.0 is the best.
The problem could have been an electrical connection or uneven wear to the rocker or injector, but check the torsional value.
jdennison:
Wow thanks a lot for the info I appreciate you taking the time, The bentley manual way of adjusting lash kind of worried me
the caveman:
I adjust the injector rockers a little more than what the VW spec is( i'm sorry I don't remember what it is, but I do about half of what they say).If you do exactly as VW says, I find they will be noisy(esp cold) and not run as well as they should. But more importantly, if the rocker was worn, so is the cam. You should think about changing it.One will not wear without them other. Common problem with those engines.
Navigation
[0] Message Index
[*] Previous page
Go to full version
