Author Topic: Starting a turbo build...Videos of it running :D  (Read 146376 times)
Reply #345June 16, 2012, 09:58:28 pm
Dakotakid
  • 1240
Re: Starting a turbo build...Videos of it running :D
« Reply #345 on: June 16, 2012, 09:58:28 pm »
Did vinegar cause that rust? Err.....was it strawberry?
Reply #346June 17, 2012, 09:33:13 am
« Reply #346 on: June 17, 2012, 09:33:13 am »
All the carnage and you guys actually read...LOL
Rust was caused as I kept it outside when I saw there was no easy way to resurect this one.
Reply #347June 17, 2012, 09:37:48 am
« Reply #347 on: June 17, 2012, 09:37:48 am »
That's obviously a yeast infection.
Reply #348June 17, 2012, 09:42:54 am
« Reply #348 on: June 17, 2012, 09:42:54 am »
thank you sir...I just spit on my monitor a little.
I waited to pull and post this stuff when I wouldn't be such an idiot about it and could take a joke. Mission accomplished. I don't feel tender about this at all now. I actually feel better as all the stuff I did *besides the extra heat* didn't hurt this engine at all. All of the main and rod bearings look unharmed. Next time I know if I hear a little bit of a slight knock to shut it down and do not restart.
Reply #349June 25, 2012, 06:27:13 pm
« Reply #349 on: June 25, 2012, 06:27:13 pm »
That is what is left of #3 in the old 1.6. The Prothe piston did not hold up as well as the valves did. Not that I think anything would have, but I will not buy these again. Just on principle if nothing else.
Reply #350June 26, 2012, 08:01:23 am
« Reply #350 on: June 26, 2012, 08:01:23 am »
Wow, that's a nice artifact.
Reply #351June 26, 2012, 09:07:28 am
CrazyAndy
  • 739
« Reply #351 on: June 26, 2012, 09:07:28 am »
Well that makes me nervous on running ARCO's in my AAZ.
Reply #352June 29, 2012, 01:44:25 pm
shwak23
  • 417
    1990 VW Golf TD. Engine Code CY
    • Blackdog Junkyard
Re: Re: Starting a turbo build...Videos of it running :D
« Reply #352 on: June 29, 2012, 01:44:25 pm »
I would use photobucket. As long as you don't move the pictures from album to album once you post them somewhere.
Sent from my DROID X2
Reply #353July 22, 2012, 07:56:06 pm
1.9aaz
« Reply #353 on: July 22, 2012, 07:56:06 pm »
I have them too and run a lot of boost/fuel and have had no problems. They are even skirt/top coated! They are OEM for Isuzu I believe. Not to worry,
Reply #354July 23, 2012, 05:43:47 pm
CarlosA
  • 139
« Reply #354 on: July 23, 2012, 05:43:47 pm »
I have that same broken spot on the bottom of a cylinder on an engine I just got to rebuild .. think its useable that way? I wasn`t sure so kinda  gave up for a bit.
Reply #355June 23, 2013, 01:40:55 pm
« Reply #355 on: June 23, 2013, 01:40:55 pm »
I was putting together my other 1.6 for this car and while rummaging for parts I found the leftover pieces of Precup from this engine. Put them up to the magnet and they are not magnetic. This tells me they were the Inconel precups. I would like to make this note as others have said that the Steel ones were better. So this failure was the Inconel precup.
For the record, I got lucky and the new head is the Steel/magnetic precups.
