Author Topic: poly urethane bushings  (Read 4600 times)
July 11, 2007, 05:10:55 am
Zulfiqar
  • 254
« on: July 11, 2007, 05:10:55 am »
Hi,
my A2 front A arm hockey puck bushings are on their way out, they have started to get loose from the rubber bonding, Is it a good idea to put poly bushes in there because its a flex bushing rather than rotating one.
I have these 80mm dia poly urethane 80 duro logs that I can have machined to make into bushes or should I be looking at getting some OEM ones.
Diesel IS the future
Reply #1July 12, 2007, 04:23:55 pm
g-spec
  • 289
« Reply #1 on: July 12, 2007, 04:23:55 pm »
If you drive the car in the winter time I would not recommend poly bushings as salt makes them brittle and they crack!!!! Stock ones are cheap as hell and will prolly last you a few years easily!!!
Reply #2July 13, 2007, 11:06:13 am
detour1999
  • 7
Re: poly urethane bushings
« Reply #2 on: July 13, 2007, 11:06:13 am »
Quote from: "Zulfiqar"
Is it a good idea to put poly bushes in there...
I had them on my '91 and found them to be WAY too harsh for daily driving (I still did for a year, but I didn't enjoy it...)
I recently replaced them with OEM R32 bushing which are slightly stiffer than stock, but not as harsh as the poly ones.  I'm very happy with them.
I got my R32 bushing from http://www.pap-parts.com/products.asp?dept=3888
(This only really applies to A2/A3 cars.  I don't think they fit A1 cars.)
-d.
Reply #3July 13, 2007, 11:38:42 pm
Zulfiqar
  • 254
« Reply #3 on: July 13, 2007, 11:38:42 pm »
thats what I thought - that bushing is supposed to flex, and poly is more like a solid, so I guess OEM is a good choice then
Reply #4July 13, 2007, 11:41:06 pm
Zulfiqar
  • 254
« Reply #4 on: July 13, 2007, 11:41:06 pm »
Reply #5July 14, 2007, 02:26:24 pm
Black Smokin' Diesel
  • 656
« Reply #5 on: July 14, 2007, 02:26:24 pm »
Stay away from poly on the control arms and rear beam. The bushings are designed to flex unlike poly. Poly puts a lot more stress on the suspension components (binding) and tends to wear out the metal around it
Reply #6July 19, 2007, 09:43:58 am
akrallysport
« Reply #6 on: July 19, 2007, 09:43:58 am »
I am also of the anti-poly camp...
R32 bushings for an OEM upgrade. For true performance, spherical bearings are the only way to go.
