I've been rebuilding pumps for 10 years and this "internal pressure" discussion is IRRELAVENT. This mod is a performance mod... not some method to skip a pump rebuild because of a worn feed pump or to fix substandard fuels. It is intended to squeeze more power out of an IDI diesel with a mechanical injection pump, not to restore or change internal pressures. Increasing the pressures to achieve this type of advance would blow the seals out of the pump. Besides, you couldn't increase the internal pressures anywhere near enough to gain the advance that this mod gives you. If you want better acceleration, mod the advance mechanism.Funny how the story changed from what is clearly a performance mod to "restoring internal pressures" and compensating for ULSD. That was not the theme of my original post, but the replies somehow shifted.... hmmmm Again, the discussion is irrelavent. It's real simple... you can do it, or you can not do it... nuff said!
You take a small punch and tap the center of the regulator in slightly to increase internal pressure. Do so in very small increments while measuring the internal pressure.
Hey Limey, What's the "exhauster"? Is it a part near the bonnet or the boot? :lol: Andrew
