Author Topic: Something for your mk2 to-do list  (Read 4663 times)
March 24, 2007, 12:36:53 pm
« on: March 24, 2007, 12:36:53 pm »
Drain/replace/flush your water seperater. The one by the rear axle. I pulled one today that had 400k kms on it and you wouldn't beleive the crap that came out, so I took pictures. No wonder you get air in the lines :shock:
btw pictures will arrive later, I didn't have my camera at the time
It's actually probably best to just delete it. Only mk2s have it, none of the later diesels do
Reply #1March 24, 2007, 04:35:48 pm
SMOKEYDUB
  • 630
« Reply #1 on: March 24, 2007, 04:35:48 pm »
man i went to drain 3 all together in all my diesel and non would ever seal again lol
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2March 25, 2007, 08:59:40 am
« Reply #2 on: March 25, 2007, 08:59:40 am »
I'm not sure how they seal as I only have a VW engine, but from working in water treatment, if they have o-rings, you need to remove them and clean them and the grooves they fit in. when water filters leak, it is always dirt/crud under the o-ring.
Reply #3March 25, 2007, 07:33:48 pm
« Reply #3 on: March 25, 2007, 07:33:48 pm »
MMM look at all the yummy stuff that was in there
It's from this thing incase anyone is confused
Reply #4March 26, 2007, 05:18:10 am
« Reply #4 on: March 26, 2007, 05:18:10 am »
Quote from: "jimfoo"
i second that... whenever i work with o-ring's and am re-using them, i always clean them thoroughly.  as well as the mating surfaces.  but i doubt it would leak that bad though.. we're only talking about 5 psi or so right???
