Author Topic: 1984 4 door rabbit for sale and other misc. parts  (Read 5902 times)
January 31, 2007, 11:54:48 am
Justin
  • 455
« on: January 31, 2007, 11:54:48 am »
The car is sold
4 speed gc trans
also 5 speed ff trans with about 120,000 miles
9 lb flywheel
IP's in unknown condition
set of grey seats sold
1.6 L dissasembled short block (11mm head) SOLD
1.5 L dissasembled short block
let me know if anyone is interested by emailing me at
[email protected]
later
Justin
www.archeryprostaffmi.com
Reply #1February 01, 2007, 12:38:47 pm
Turbinepowered
  • 1206
« Reply #1 on: February 01, 2007, 12:38:47 pm »
The two disassembled engines, are they complete with all the parts, or just partials with the major pieces?
Reply #2February 01, 2007, 02:03:33 pm
Justin
  • 455
« Reply #2 on: February 01, 2007, 02:03:33 pm »
the car has a fully assembled engine in it
after the parts that go with the car to get it running these are parts that are left over
the two dissasembled engines are the short blocks only, I have one cylinder head to go with one of them with camshaft (I might have 2 heads but I cannot remember)
so they have block, crank, rods and pistons, seal plates, oil pans, oil filter flanges, there are motor mounts/pump mounts, I know I have some water pump housings, alternator brackets (cheap steel ones) and one for a car with AC, and an extra alternator, valve covers. I have a set of new never installed rings with most of the little gaskets.
these engines are mechanical valvetrain and I have the shim kit as well
also 2 door window glass and chrome or aluminum trim for around door windows
extra set of 13x4.5 wheels
2 or 3 intake and 1 exhaust manifold
anything else you need
Reply #3February 21, 2007, 06:01:25 am
Justin
  • 455
« Reply #3 on: February 21, 2007, 06:01:25 am »
doesnt anyone want any of this stuff? reasonable offers and you can take the stuff home or I will ship it
thanks
Justin
Reply #4February 21, 2007, 07:00:50 am
Turbinepowered
  • 1206
« Reply #4 on: February 21, 2007, 07:00:50 am »
I'd snag the disassembled 1.6, but I'm looking for turbo instead of NA.
Reply #5March 03, 2007, 09:53:34 pm
Turbinepowered
  • 1206
« Reply #5 on: March 03, 2007, 09:53:34 pm »
You still have your assortment of parts? I might be able to buy and pick them up come May, when I'm up around Chicago anyway...
Got a TD injector pump in amongst your parts lots?
Reply #6March 05, 2007, 05:40:45 am
Justin
  • 455
« Reply #6 on: March 05, 2007, 05:40:45 am »
Sorry I dont have a TD pump, thats the toughest thing to find in my area
other parts that I have include a TDI clutch and pressure plate for the newer style transmissions, I would have to get part numbers for you for exact application
newer style TDI injector lines (brand new)
Reply #7March 05, 2007, 07:32:42 pm
Turbinepowered
  • 1206
« Reply #7 on: March 05, 2007, 07:32:42 pm »
Was it the 1.5 or the 1.6 that you had the head and cams for? I'm actually looking to maybe pick up that 1.5 you have; need spare parts for the Dasher I just bought.
Reply #8March 06, 2007, 06:04:01 am
Justin
  • 455
« Reply #8 on: March 06, 2007, 06:04:01 am »
I had 1.5 parts, I will double check to see what I have left, My dad sold some parts this week and I know the guy was debating over the 1.5 or 1.6, they are both the 11mm headbold so the heads and cams are interchangable.
I will get back with you on it in a few days
later
Justin
Reply #9March 19, 2007, 09:09:12 am
Justin
  • 455
« Reply #9 on: March 19, 2007, 09:09:12 am »
Car is sold as well as engine parts
so all I have left are a set of light blue front seats
1 injection pump pending sale
99.5 and later aluminum TDI oil pan with oil pump and pickup
99.5 and later TDI valve cover
4 speed gc trans
9 lb flywheel
chrome rear bumber from 1980 rabbit
Let me know if you are interested in any of this by emailing me at [email protected]
