Gas Tachometer Conversion to Diesel W terminal - '87 Vanagon
Topic: Gas Tachometer Conversion to Diesel W terminal - '87 Vanagon (Read 32411 times)
January 24, 2007, 12:57:16 am
orbitald
January 24, 2007, 12:57:16 am »
Hi, my first post so please forgive any mistakes.
I followed regcheeseman brilliant lead and modified a ’87 Vanagon gasser tachometer to diesel. I know my modified board looks a little hack but all the parts I garnered from an old smashed up monitor I found down on Mission street.
R1 = OK ( 100 ohm )
R2 = OK (I think 82 ohm or 72 ohm is OK)
R3 = Remove
R4 = OK ( 191 ohm )
R5 = Remove
R6 = Replace with 10K ohm
R7 = Replace with 15K ohm
R8 = Remove
D1 = Replace with wire link
C1 = Replace with 10nF (nanoF)
C2 = Replace with 47nF (nanoF)
C3 = OK ( 22uf )
C4 = New 3.3uF (microF) across output terminals (I used a 4.7uF and it worked fine)
Adjust RV1 to middle range
Hope this is some helpful stuff and thanks cheeseman!
Let me know if you find any problems with the drawings / diagrams.
January 26, 2007, 02:21:32 pm
Hillshy
January 26, 2007, 02:21:32 pm »
welcome orbitald
i did this to on my vanagon too, as mine used to be a thursty gasser, works a treat don't it! it just completes any diesel conversion.
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
February 04, 2007, 09:05:27 am
Typrus
February 04, 2007, 09:05:27 am »
Whoa...
Are most gasser tachs about like that? I dunno if I'll be able to find a Rabbit diesel instrument cluster for the Kart, so I need to keep such options open, ja?
1995 Toyota Camry 2.2L 5-speed
1984 Toyota Tercel 4wd Wagon 1986 " " " "
1996 VW Passat TDI 1Z w/ KermaTDI Stage 3 kit
1999.5 F-250 7.3L Powerstroke
2002 Excursion 7.3L Powerstroke (Dads)
February 04, 2007, 12:19:39 pm
orbitald
February 04, 2007, 12:19:39 pm »
It’s not too hard to calibrate. I purchased a cheap digital tachometer off ebay (~$24 plus shipping) and took readings off they main crank pulley. There is a small hole in the back of the tach housing that gives access to the potentiometer screw which adjust the range. The biggest trick was getting the needle back to its original position. I think it could be done in about 5min with two people but I did it with myself and it took about 15min.
And I'm not sure about other Vanagon gasser tachometers. I am getting a couple in the mail soon and I'll take a look.
David
February 08, 2007, 09:44:20 am
Fredwanagon
Newbie
86 1.6TD tach in a 82 diesel vanagon
February 08, 2007, 09:44:20 am »
When I saw your post, I started to fit my (around 86 1.6TD tach) in my Diesel Vanagon. Mechanicaly, I had to modify the tach cassing to center the round plate in the vanagon cluster clock hole.
Now phase 2 is to plug fuel gauge, water temp and tach.
Fuel gauge, water temp are easy to figure out. I will extend with a wire from the circuit bord to the guage. (Can I weld a wire on the circuit bord witout melting it?)
The tach has a four pin connector in the back. 3 are used.
Do you know wich pin is the w signal and wich pins are + and -?
I can post pics if you need to see it.
Thanks
Fredwanagon
Westfalia 1.6TD Project
February 08, 2007, 02:43:52 pm
February 08, 2007, 02:43:52 pm »
Yes you can solder a wire directly to a circuit board trace.. two tips:
- careful with the heat... too much and the trace will delaminate
- most circuit boards have a solder mask... a non-conductive (sometimes clear) coating that needs to be gently scraped off to expose the copper trace below.
February 08, 2007, 06:24:42 pm
Fredwanagon
Newbie
February 08, 2007, 06:24:42 pm »
Do someone know wich signal correspond to the letters A,B,C,D and E?
see immage on:
http://www.vwquebec.ca/forum/viewtopic.php?t=47110&highlight=
Thanks
Fredwanagon
February 13, 2007, 12:13:24 pm
orbitald
February 13, 2007, 12:13:24 pm »
Hey Fredwanagon,
Look up at the circuit board in my original post (orange board with the green traces) and you can see the pinout on the board:
In = W Signal In
+ = +12VDC positive
NC = No Connection
- = GND
You can look at the connector to see which pin is missing (NC) to orientate yourself
Good luck,
OrbitalD
August 14, 2008, 08:55:19 am
orbitald
Problems with tach conversion
August 14, 2008, 08:55:19 am »
Hey,
I have had problems with this conversion and ended up buying a jetta diesel tach and installing it into my vanagon cluster. Until I have a bunch more time to figure out exactly what is wrong with this circuit I advise folks not to try this.
Best,
D
August 15, 2008, 02:24:56 pm
Otis2
August 15, 2008, 02:24:56 pm »
You have an AAZ in your Vanagon, right?
I have the same AAZ setup in my van, with the 1.6TD diesel tach in the '85 Vanagon cluster. (It says "2,22" on the tach face, right?)
I'm curious how you calibrate your tach to fit with the signal from the alternator on the AAZ engine.
Mine was way off, far overreading. I had to replace one of the resistors to get it to read accurately.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=12589
August 15, 2008, 02:32:36 pm
regcheeseman
August 15, 2008, 02:32:36 pm »
All looks fine but the chip.
can you swap in a chip from a later instrument. SUch as your jetta tach?
What was wrong in operation anyway?
Reply #11
November 25, 2008, 08:27:53 pm
kendalwoolf
Newbie
Reply #11 on:
November 25, 2008, 08:27:53 pm »
I just rewired my 1986 Vanagon tach using the schematic on this post and it works fine with my 1.6 Turbo Diesel, running off the W terminal of the Alt.
Check out pictures of the conversion here:
http://picasaweb.google.com/kendalwoolf
Reply #12
November 26, 2008, 10:35:55 pm
Quantum TD
Reply #12 on:
November 26, 2008, 10:35:55 pm »
Just for schnitz and giggles, has anyone else done this mod, and if so, how is it working out?
I just found a tach cluster out of a 1987 Vanagon at my local Pick and pull for $20. Some goon thought he had 'hid' it in the truck of a Mercedes wagon, but I found it.
Anyway, I wanted to hook up a tach for my dad's vanagon. It was a 1.6NA, but we dropped in a 1.9IDI last summer.
Thanks.
Reply #13
January 15, 2009, 08:40:33 pm
orbitald
Reply #13 on:
January 15, 2009, 08:40:33 pm »
Well I'm glad someone got it to work consistently. Mine was intermittent and I just got tired of fooling with it so I slapped in a diesel tach. Regcheeseman talks about using a different chip that's probably worth a try. To calibrate it there is a little hole in the back that adjusts the pot on the board. Fairly easy but its not exactly linear.
If anyone else gets this going let us all know.
David (in orbit)
Reply #14
May 11, 2010, 12:22:10 pm
jf9191
Newbie
Re: Gas Tachometer Conversion to Diesel W terminal - '87 Vanagon
Reply #14 on:
May 11, 2010, 12:22:10 pm »
Does anyone have some left over resistors or transistors they would sell me? I cannot find the 10nf capacitor anywhere and its really frustrating. I thought these parts would be really easy to find.
