Author Topic: TDI, TD, GTD nozzles + Inj Pump seal kits ULSD+BioDsl ready  (Read 36099 times)
November 30, 2006, 04:40:43 am
Smog
  • 160
« on: November 30, 2006, 04:40:43 am »
TDI, TD, GTD nozzles + Inj Pump seal kits ULSD+BioDsl ready (TD and TDI)
uprated 1.6GTD nozzles (RA/SB engines )
stock 1.9TD nozzles (AAZ engines)
0.205mm and 0.216mm nozzles for the TDI
IDI injection pump seal kit (1.6D 1.6TD and 1.9TD)
TDI injection pump seal kit (1996-2003 TDI)
IDI Pump shaft seal for pump sucking air
I can do COD for canadians (add 5$)
www.veg-injection-service.com
www.VEG-Injection-Service.com
1.6GTD nozzles (RA/SB )
1.9TD nozzles (AAZ )
0.205mm or 0.216mm TDI nozzles
IDI Pump shaft seal
Reply #1November 30, 2006, 01:03:47 pm
LeeG
  • 401
« Reply #1 on: November 30, 2006, 01:03:47 pm »
Do you still install and shim nozzles if someone sends injector bodies?  How much for that?
How about the special socket for IP dissasembly?
'97 Passat TDI
Reply #2December 01, 2006, 04:23:49 am
Smog
  • 160
« Reply #2 on: December 01, 2006, 04:23:49 am »
Quote from: LeeG
Sorry,
no more pop-testing on injector. You may ask your local BOSCH certified shop if they can do it for you
IDI Pump shaft seal
Reply #3December 05, 2006, 01:34:34 pm
« Reply #3 on: December 05, 2006, 01:34:34 pm »
nooo smog you dont pop test injectors anymore? i'm guessing something bad happened?
Reply #4December 06, 2006, 04:28:07 am
Smog
  • 160
« Reply #4 on: December 06, 2006, 04:28:07 am »
Quote from: jtanguay
Simply too much time consuming for a guy with 2 kids under 18 month old....
IDI Pump shaft seal
Reply #5December 06, 2006, 06:17:59 am
DELETED
« Reply #5 on: December 06, 2006, 06:17:59 am »
DELETED
Reply #6December 06, 2006, 06:19:06 am
Smog
  • 160
« Reply #6 on: December 06, 2006, 06:19:06 am »
Quote from: DragonsMaw
Do you have 1.6D seal kits in stock?
Yup,  everything is in stock ready to ship
IDI Pump shaft seal
Reply #7December 06, 2006, 04:08:11 pm
commuter boy
  • 277
« Reply #7 on: December 06, 2006, 04:08:11 pm »
Quote from: Smog
Ah, wait a year or so, then you can get them to pump the handle for Papa.
 :D
Reply #8December 07, 2006, 04:28:52 am
Smog
  • 160
« Reply #8 on: December 07, 2006, 04:28:52 am »
I may show them how to rebuilt my 1972 beetle; it will be better for customers
IDI Pump shaft seal
Reply #9January 14, 2007, 11:01:21 am
commuter boy
  • 277
« Reply #9 on: January 14, 2007, 11:01:21 am »
Do you have seal kits for the 2.4 5 cyl AAB engines that were in the Canadian Transporters?
I'm curious as to how much of the 1.9 seal kits would match with them, the pumps look fairly similar on the outsides......
Reply #10January 15, 2007, 04:05:11 am
Smog
  • 160
« Reply #10 on: January 15, 2007, 04:05:11 am »
Quote from: commuter boy
the injection pump is similar but the kit I sell will be missing 1 small copper seal for the fifth delivery valve on your pump.  I don't think it's a problem as they are rarely leaking but just to let you know. The rubber parts are all the same
IDI Pump shaft seal
Reply #11February 15, 2007, 02:43:18 pm
insdtanoodles
  • 148
« Reply #11 on: February 15, 2007, 02:43:18 pm »
Is it just as easy as to take the old nozzels from my aaz and put new ones in or do the the new ones have to be shimmed and pop tested?
1996 vw jetta AAZ
Reply #12February 16, 2007, 04:06:07 am
Smog
  • 160
« Reply #12 on: February 16, 2007, 04:06:07 am »
Quote from: insdtanoodles
the fabrication tolerances are tight, they can be reinstalled without pop-testing but if the car got over 250000km, it's a lot better to have the injectors reshimmed to the oem opening pressures.
they will work fine without shimming, you'll get the power, mpg and driveability gain but pop-testing them is the icing on the cake
IDI Pump shaft seal
Reply #13February 16, 2007, 01:46:33 pm
insdtanoodles
  • 148
« Reply #13 on: February 16, 2007, 01:46:33 pm »
I guess I should get them shimmed then, cars got 247000km on original injectors
1996 vw jetta AAZ
Reply #14June 07, 2007, 06:11:23 am
red64chevelle
  • 67
« Reply #14 on: June 07, 2007, 06:11:23 am »
I just payed via PayPal for the injection pump seals, and GTD nozzels.  I can't wait to finish my "GLD" project.
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
1964 Malibu Convertible
