Author Topic: rebirth of the the GTD  (Read 8364 times)
November 04, 2006, 07:48:28 pm
fuslit
  • 118
« on: November 04, 2006, 07:48:28 pm »
First off, sorry for the long post :) As promised, this will be a buildup thread
This will be a long background story...
The first car I had was an 82 NA rabbit diesel LX. I hit a cow with it coming home from work @ three am in the morning. :(
Believe it or not, I escaped that crash with only cut knuckles! Scared the heck out of me, but did not make love for driving vw's any less!
The next car I had was an 85 8 valve gli, and I loved that car! I've been through a few since (only vw thank you very much.) All Gas though, I missed my diesel rabbit (how reliable it was, easy to work on, and the cheapness of parts... Vr6's are fun to drive, just expensive to maintain...)  I bought a cheap(ish) yellow diesel rabbit which was in questionable shape (The intake was held on by zip-ties and 1 bolt!!!) The rest of the bolts had sheared off.... I was able to back most out of the block and got it up and running with 5 of the 7 bolts holding the intake on, the body unfortunately had quite a bit of the rust syndrome... But the engine started every time last winter!!! I drove it every day and did not put it on a block warmer once. (pretty impressive compared to my 1st car which needed the block heater to start in the 32 and below weather.) but with my first car I was young and inexperienced so I probably missed a simple thing I could have fixed it. Anyway here's a picture for the sake of the background story....
Through my lurking on Vortex I found some posts by Joe (RabbitGTDguy) about his GTD and I fell in love with his car. I was (am?) excited about the untapped prospect of power AND great gas milege! so I started to pull together some parts to build up a turbo diesel. But I started having second thoughts about dropping the $$$ on a motor to put into something who's body was 'questionable' at best.
Found a caddy which from the pictures I saw had quite a bit of potential, it didn't run but originally was diesel and had a clean title! so I traded the yellow Bomb and a cabrio that I had picked up for the caddy sitting in my garage
At the time it seemed like a good idea... from what I could tell in the pictures the body was in good shape.... Ahh not being able to see under the truck with 1 foot of snow hid the rust on it that... Anyway, I still was going to proceed with my TD project. In the meantime, I figured I may as well get it running and on the road. While I'm in the process of tearing down and rebuilding the 1.6td block.
The parts I bought, I bought 2 motors who's TB's had broken/slipped. One still had the head on and I had hopes that it only had 'slight' contact unfortunately it turned out to be the worse of the two. the other engine had major valve impressions on the cylenders. I traded a 1.6TD Injection pump to Joe for some 1.6 pistons which are in great shape. (compared to the others I got) and started tearing down the motor that was the better of the two.
The block appears to be in ok shape, there is a part that is broke off that apparently the power steering attaches to according to a friend of mine. I think I'm going to build it up anyway and run it. I have a few turbo's in various stages of disrepair, the one that is in the best shape is an eco turbo. It will be the 1st one to go on.
Here's a couple shots of the shell, in Joe's Garage it's got a couple rust spots that need to be taken care of. I will need to get a suspension for it, basically this is the blank slate to work from building the car from the ground (almost) up.
Found a sweet set of rims that I plan on running for a decent price (the pic is a little dirty but it's all I have at the moment)
That's pretty much it for now, I will post more when I get the shell here and the block back from being hot tanked and honed. I have a massive intercooler and new fender flares to go on. I haven't decided what else I want to do to the car, I've been kicking around the idea of a mk3 dash (and have a full swap) but I may go w/the old school style dash as well...
More to come as this project develops develops.
-Todd
'81 rabbit 4dr 1.6TD [project]
'98 jetta tdi [daily]
Reply #1November 04, 2006, 09:52:13 pm
« Reply #1 on: November 04, 2006, 09:52:13 pm »
nice pics!  that engine stand is from princess auto isnt it!!!!  I bought one just like it when it was on sale for around 70 bucks!  can't go wrong with that!
Reply #2November 05, 2006, 05:14:39 am
bert
  • 423
« Reply #2 on: November 05, 2006, 05:14:39 am »
Hi,ive just built a GTD in the u.k. believe me they are great fun  :wink:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=5082
bert
Reply #3November 05, 2006, 05:28:32 am
fuslit
  • 118
« Reply #3 on: November 05, 2006, 05:28:32 am »
We don't have Princess auto here... Could be from autozone (a similar store) I'm not sure where it's from though, I bought it off a kid for $50 bucks which I thought was a pretty good deal. It's a pain to get in the center my engine hoist of with the two outer 'legs' But for $50 it's a deal :)
Found a pic of the intercooler and new flares
The intercooler was on a friends 300hp rabbit, :shock: he had it custom built to his specs (of which I don't know off the top of my head.) I think it should be able to keep things pretty cool on the GTD. I'm going to look into a non-overflow radiator to clean the engine bay up and give me some more room to run stuff.
Got a spot in the garage cleaned up yesterday in  preparation for the rabbit's arrival. A friend of mine has the car casters (I think that's what their called.) they let you move the car around w/out having back it up, steer move forward, backup steer, move forward, repeat. I'm going to look into how much they cost, they save quite a bit of work and when I need to work on the rabbit I can just push it into a spot that would be convenient.
-Todd
Reply #4November 05, 2006, 05:55:37 am
« Reply #4 on: November 05, 2006, 05:55:37 am »
Looks good. I really need to get a garage so I can work on my cars.
If you need any rabbit parts let me know, I have piles of them and I just want them gone to make a bit of walking room
Reply #5November 05, 2006, 08:17:09 am
« Reply #5 on: November 05, 2006, 08:17:09 am »
do a burn out
Reply #6November 05, 2006, 10:19:50 am
DVST8R
  • 535
« Reply #6 on: November 05, 2006, 10:19:50 am »
Princess Auto = Harbor Frieght in the USA.  :wink:
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #7November 05, 2006, 10:50:56 am
RabbitGTDguy
  • 1274
« Reply #7 on: November 05, 2006, 10:50:56 am »
Good to see your ready for her Todd...will be glad to work with you and see it back on the road sooner than I could at the current moment!
Joe
1972 VW Westfalia
Reply #8November 05, 2006, 01:57:24 pm
Turbinepowered
  • 1206
Re: rebirth of the the GTD
« Reply #8 on: November 05, 2006, 01:57:24 pm »
I'll ask a total newbie question here, but searches haven't answered it so I don't feel bad asking: What's "hot tanking"?
I'm serious; never been into the engine rebuilding scene beyond a few ACVWs, and did pretty much all the work on those myself since it was all stock stuff.
Looks like it'll be one sweet ride when you're done.
Reply #9November 05, 2006, 02:10:34 pm
jackbombay
  • 599
« Reply #9 on: November 05, 2006, 02:10:34 pm »
Hot taning is droping theblock in a tank of hot water/chemicals to get it really clean.
Reply #10December 03, 2006, 05:31:46 am
fuslit
  • 118
« Reply #10 on: December 03, 2006, 05:31:46 am »
http://fuslit.org/photo_gallery/index.php?album=misc/car/turbo_diesel_buildup/12-02-06_moving_the_rabbit/
I was absolutily beat last night after this trip, I drove 200+ miles down and back then down and back again to drop my brother's truck and the tow dolly off. It was the first time I'd driven a tow dolly, but I think it went fairly well, a couple snags but nothing that caused the day to be anything less then a success!
A big Thanks to Joe (RabbitGTDGuy) for riding shotgun, it helped more then you know...
and now the pics (crappy cell phone pics sorry) you've all been waiting for :)
Dont' go to the light Joe!!!
Got it on the dolly
Joe's Sweet sweet rides
his M-TDI build was fantastic (we were on such a tight time frame weather wise I didn't get to go for a spin with it, but I guess it got power that is 'neck snapping') After hearing it run, I belive it! I can't describe the sound but it's pretty agressive to say the least!
I thought this sticker is hilarious
Safe at home
Tucked away in Bed
Thanks Joe, for the oppertunity to give the shell with a lot of history a new leaf in its book (and a new lease on life!) So much to do on this shell... Rust repair, re-run brake lines, etc. BUT The engine build is next and I hope to have that coming along between now and spring. I was checking out the heads that I have and they all have a few things that are shot, so I'm contemplating a 1.9td head on a 1.6 block. I know the jury's still out on this. What are your thoughts?
-Todd
Reply #11December 04, 2006, 07:28:06 am
fuslit
  • 118
« Reply #11 on: December 04, 2006, 07:28:06 am »
Again, sorry for the crappy cell phone pics.
Got my head studs today on my trip up to Canada to visit my sister in Niagra falls, had a bit of a traffic problem on the way home and we were stuck on the thruway for 1/2hour to 45 minutes longer then usual. People are idiots and it was snowing so you do the math but this was the end result...
<rant>
Also as a side note I would like to add, Fog lights are for fog, not the thruway when it's clear with no fog/rain/snow. if you have fog lights and you drive with them on in the middle of traffic on the thruway your an idiot. When your behind someone, Their bright as hell and when traffic flows at 0-5 miles an hour annoying as hell to the person in front.
</rant>
Moving on :)
The head studs are bigger then I pictured they would be but I'm psyched, they look awesome! Thanks again Dr Diesel!
Took a pic of the engine bay...
-Todd
Reply #12December 04, 2006, 07:59:39 am
« Reply #12 on: December 04, 2006, 07:59:39 am »
Quote from: "fuslit"
You should have made yourself a nice smoke screen to block them out :lol:
Reply #13December 04, 2006, 09:16:06 am
Benjamin
  • 485
« Reply #13 on: December 04, 2006, 09:16:06 am »
Is this a M12 x 1,25mm wire?
how long is the bolt without the head?
Greetz, Benjamin
Must make +250hp
Reply #14December 04, 2006, 08:20:38 pm
fuslit
  • 118
« Reply #14 on: December 04, 2006, 08:20:38 pm »
I measured the one of the bolts w/out the nut on it, the whole length is about 133mm? (guessing here, all I have is a plastic gauge from boltdepot.com)
one end looks to be M10x1.25 (this side is what tightens against the head with the nut on it) the other end M12x1.75 this is the end that goes in the block?
I need to get a copy of the directions a friend of mine has, the originals these had ran into a unfortunate accident when the PO dropped the directions into some used motor oil...
-Todd
