Author Topic: Question about "full time boost" mod  (Read 5496 times)
September 28, 2004, 12:11:51 pm
Topherdiesel
  • 132
« on: September 28, 2004, 12:11:51 pm »
So I went to do the fuel cutoff selenoid mod an my AAZ motor, and I also wanted to do the "permanent boost" mod, the one where you have to open the cover and use a tie wrap on a switch of some sort.
Only when I look at my injection pump, I do not seem to have the switch as SMOG does in his pictures???
it is simply not there, the spring and assembly for my throttle cable linkage are right basically where it looks like his switch is!
This is the mod I am talking about!
"1. It is necessary to unscrew the screws #1 and #2 and to withdraw the limit-switch. (you probably have a cover over), You can use tie-rap and fix the switch elsewhere (but it must remain open)
This modification makes it possible turbo to function full-time instead of compressing only when you ask for all the power. "
Basically, it all looks the same except the fact that i do not have the switch there, nor the cover.
I have the silver ciorcular thing to the right of 1 and 2 in the picture, but to the left of mine, there is only throttle linkage?????
HELP!!!
DO i just not have this, cuz I could swear I hear my turbo spooling almost always?
Reply #1September 28, 2004, 03:14:20 pm
QuickTD
  • 1156
« Reply #1 on: September 28, 2004, 03:14:20 pm »
What year and model is your car? Most AAZ engines older than '94 don't have this switch. These cars have either a garret T2 or KKK K14 turbo and make boost full time, there is no changeover valve and no need for this mod.
Reply #2September 28, 2004, 03:47:41 pm
Topherdiesel
  • 132
« Reply #2 on: September 28, 2004, 03:47:41 pm »
yep, mines a 93, so are all the other mods the same??
Reply #3September 28, 2004, 04:00:04 pm
QuickTD
  • 1156
« Reply #3 on: September 28, 2004, 04:00:04 pm »
Pretty much. With the exception of any mods dealing with boost adjustment. The T2 and the K14 both have non adjustable wastegate linkages, similar to the older 1.6TD units. You will need to use a bleed or a "dawes device" type of boost control to raise the boost pressure.
Reply #4September 28, 2004, 04:01:20 pm
Topherdiesel
  • 132
« Reply #4 on: September 28, 2004, 04:01:20 pm »
How about a TURBOSMART Manual Boost Controller out of my old talon?
Reply #5September 28, 2004, 05:15:28 pm
QuickTD
  • 1156
« Reply #5 on: September 28, 2004, 05:15:28 pm »
That would be kind of like taking a gun to a knife fight,  :D  but it would work just fine.
Reply #6September 28, 2004, 09:30:59 pm
Topherdiesel
  • 132
« Reply #6 on: September 28, 2004, 09:30:59 pm »
I'll shoot the MOFO!!
:p
Hahaha, I also have my old PROFEC -B !!!!
But THAT would be overkill eh!
:p
