Author Topic: shortcut for priming injection pumps  (Read 29072 times)
September 05, 2004, 06:32:50 pm
Dr. Diesel
  • 1341
« on: September 05, 2004, 06:32:50 pm »
Here's a quick way to get an engine going that's been replaced or sitting long enough for the fuel to drain back into the tank. Fill a clean container (like an oil quart bottle) with fresh fuel. Remove the pump's supply hose from the fuel filter and stick it in the bottle. Crank engine, and observe fuel being pulled from the bottle. (you might first pour a little in the line to wet the pump if it's been sitting) When the engine starts and settles into a smooth idle (relatively speaking, of course) quickly pull the hose from the bottle and slip it back over the fuel filter outlet. Grab the throttle and rev the engine up. It'll probably slow down, cough and buck a bit,  but should draw fuel from the tank before the pump uses up it's internal fuel.
Voila! No more cranking the starter for minutes at a time!
Reply #1September 06, 2004, 06:47:45 am
VWRacer
  • 649
« Reply #1 on: September 06, 2004, 06:47:45 am »
Dr Diesel, I once ran my NA Rabbit out of diesel, but got it running right away by using the following trick. I loosened the nut on each injector, then had my wife hit the starter while I watched for fuel. Within 5 to 10 seconds I could see fuel beginning to ooze out from around the nuts, asked her to stop cranking, then tightened the line nuts back up and had her hit the starter again. The engine fired right up. It ran rough for a few seconds, but as soon as what little air was in the system was purged, there was no problem.
I think the key thing is to purge the air as much as possible before trying to start the engine. If the injector pump has to "inject" a pint or so of air before it can start injecting fuel, as you say, it's gonna take a while! By cracking the line nuts, though, you give the air an easy escape route and the pump can start injecting fuel within seconds.
Stan
OTOH, I once ran the Cat 3208 in my motor home out of fuel, too!  :?  :roll:  :cry:
Stan
C-Sports Racer
Reply #2September 06, 2004, 01:57:41 pm
fspGTD
  • 1529
« Reply #2 on: September 06, 2004, 01:57:41 pm »
The only problems I've ran into with getting a pump back up and running is after it's been removed from the car, when the fuel is drained out of it's housing...  if you merely run the fuel tank dry, there still seems to be an adequate volume of fuel inside the pump housing that is is "self priming" - IE: you can get it going by just cranking over the engine (long enough.)
If the pump housing is totally dry though, say after you've had the pump removed and it's been laid on it's side so all the fuel has drained out, then in that state, it seems that even with fuel at the fuel supply union, and no matter how much cranking with or without the injectors cracked, the pump just can't prime itself.
What I've been doing most recently is hooking up one of those outboard motor fuel line hand-squeeze bulbs into to the fuel supply line, and squeezeing on that bulb hard to get fuel forced though the pump.
A method that works easily on only an NA diesel is to use a turkey baster to squeeze clean diesel fuel directly into the pump housing through the fuel outlet port (remove the banjo fitting on top of the pump there.)  Getting it into the fuel stop solenoid port works also as it's also connected directly to the main, high-pressure cavity inside the pump.  When primed this way, the pump will start firing the engine virtually immediately.  However, this method is hard on a turbo pump, because the LDA device is in the way of easy access to the fuel outlet hole.
Jake Russell
Reply #3September 07, 2004, 05:34:15 pm
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
pump priming
« Reply #3 on: September 07, 2004, 05:34:15 pm »
what i do in my shop is to blow compressed air into the return line
of the vehicle (take off the filter) and watch the fuel flow into and out
of the pump.... don't blow too hard or you'll blow the tank up.
Giles
Reply #4September 07, 2004, 08:11:08 pm
Dr. Diesel
  • 1341
Re: pump priming
« Reply #4 on: September 07, 2004, 08:11:08 pm »
Quote from: "Giles@superiorFuelInj"
Giles
geez. I should have read the whole post. oops!
Reply #5September 18, 2004, 01:14:25 pm
caddywompus
  • 27
    • http://www.greaseworks.org
« Reply #5 on: September 18, 2004, 01:14:25 pm »
I've had great success priming the IP by removing the return line from the pump (the line that goes back to the tank), and pulling a vacuum on the IP OUT fitting with a hand-operated vacuum pump.  Of course, this will also uncover any air leaks in your injector return hoses, but as long as these are all tight, this method is very easy and relatively clean.
Justin
81 Caddy 1.6TD
82 Vanagon Westphalia 1.9TDI (1Z)
96 Passat Wagon 1.9 TDI
Reply #6November 07, 2004, 12:43:45 pm
ejust
  • 124
priming the pump
« Reply #6 on: November 07, 2004, 12:43:45 pm »
Hers my $.02 worth. I did this to see how the injectors sprayed and how well the pump worked. Youll need a battery charger, fairly powerful drill, 19mm socket (1/2" drive), 19mm bolt and 19mm nut for bolt. Slip the bolt into the socket backwards(threads thru the square hole), install nut (spacers may be needed depending on bolt if threaded all the way). and grind the end of the bolt down so you can chuck it up on the drill (to about 5/16 or 8mm). The 19mm nut clamps the socket in in place to bolthead. Use the drill to spin the pump over. Use the charger on low 12V setting (2A or less) and hook red to solenoid lead and black to pump housing. Insert infeed line into fresh clean fuel and have an outfeed line and catch jar for return. Chuck up the homemade 19mm socket bit into drill, turn on charger, and spin away!!! <- make sure your lines and injectors are connected firmly AND YOU WEAR SAFETY GOGGLES!! You can watch the injectors at different rpms (my drill goes up to 1200rpm) and opening and closing the throttle.  You can use this trick to prime the pump if IP was removed. Reinstall IP on car inc lines and injectors but leave the lines loose at the injectors. Hook infeed and return lines all up. Spin the pump over till you get fuel leaking out. Torque lines to spec. Spin IP over for only a couple more seconds with throttle open.  Most if not all air will be gone and you should get instant start up.  Sorry it was long winded but hope it helps!
V-dubs r cool n Audi's rule,
German cars make me drool!
'86 Jetta TD (Hoop-D)
'86 Audi 5000S
Reply #7October 15, 2005, 02:18:12 pm
Fisher
  • 148
IP Priming
« Reply #7 on: October 15, 2005, 02:18:12 pm »
I just remove the return line from the pump and push on a piece of clear hose and suck on it till you see fuel in the clear line.  Easy, remove clear line and replace with return hose, You're done.
Reply #8October 16, 2005, 06:02:38 pm
  • 2922
priming
« Reply #8 on: October 16, 2005, 06:02:38 pm »
Only thing I can think to add is if the pump has been sitting for a long time, it's a good idea to replace the "OUT" bolt with a normal banjo bolt that doesen't have a restrictor and screen.
 Disconnect the power so the injectors don't get fuel and use one of the many good ideas above to get fuel coming out the return line.
 Plug in power and crank it over. Let fuel flow through the injection pump for awhile and flush any bacteria colonies, rust or chunks from the pump body.
 Then swap the "OUT" bolt back in.
Reply #9October 18, 2005, 06:10:54 pm
VW Scully
  • 245
    • Not Quite Tom Riddle's Diary
IP priming
« Reply #9 on: October 18, 2005, 06:10:54 pm »
These are good ideas :) I am going to be storing my Rabbit this Winter and will be replacing all the fuel lines with Viton (since I run BioDiesel), so this is good to know, should I need to remove the pump.
Thanks guys!  8)
Tara aka VW Scully
**1981 Rabbit Diesel L, Biodiesel driven: 'the Bio-Bunny' **
Advocate for Young Adult Cancer Research & Support: I'm too Young for This!!
http://www.i2y.com
Reply #10October 18, 2005, 09:42:16 pm
Master ACiD
  • 328
« Reply #10 on: October 18, 2005, 09:42:16 pm »
where do you get this urethane that is 12 times cheaper?
thanks.
Reply #11October 19, 2005, 06:14:07 pm
VW Scully
  • 245
Urethane
« Reply #11 on: October 19, 2005, 06:14:07 pm »
I have a friend who works at a motorcycle supply company so I will ask him about it :). I also bought all my hoses/clamps etc. for my BioDiesel processor at a local hose/tubing place so will check there too.
I was going to get the Viton through my local VW shop and yes, it is expensive!  :shock:
Tara aka VW Scully
http://www.i2y.com
Reply #12November 10, 2005, 11:13:17 pm
mortskeg
  • 95
    • http://www.vwcaddy.com
« Reply #12 on: November 10, 2005, 11:13:17 pm »
I've been running the urethane fuel line for about a week now and from my local powersports store it only cost me just over $8 for the 4' of 1/4" and 5' of 5/16".  Hopefully the fact that I feed the squirlles peanuts and the garage will keep my new fuel lines safe for some time.
I just need to figure out something for the large diameter filler-tank rubber and pump seals and I will be 100% ready for B100.  Thanks again. :D
Reply #13November 11, 2005, 11:26:00 am
mortskeg
  • 95
« Reply #13 on: November 11, 2005, 11:26:00 am »
I was wondering why the squirrels started running down the trees tail end first. :P   Good to know info for the squirrel lover/hater.  Sorry about the thread jack.
Reply #14December 11, 2005, 09:23:45 am
hillfolk'r
  • 1532
« Reply #14 on: December 11, 2005, 09:23:45 am »
as far as priming up a pump,,a few of these methods have worked for me,,,cracking lines loose works good,,,,,,ive aired up the tank too,,thats ok,,just dont blow the tank,,,im using a lift pump currently,,so priming isnt bad,,,,for the "pump that has beenlayin on its side",,ive taken a syringe+put in a few oz of atf,,its thicker than diesel fuel,and coats inside of pump for prime,,,,,,at work,on big old detroit 2 strokes,,ive added motor oil in the fuel inlet,,cause the gear pump(liftpump) can be fussy at pulling fuel,,,,,the fuel priming bulb works good too,,,,,,,,,
Throttle cables ftw
