Author Topic: photos of Garrett T3 on AAZ in van  (Read 5680 times)
April 11, 2006, 08:45:56 pm
Otis2
  • 191
« on: April 11, 2006, 08:45:56 pm »
I thought I'd post photos of the Garrett T3 turbo that has replaced my original KKK K03.  The AAZ engine is installed in the back of a Vanagon Westfalia.
The intercooler that I use is a Garrett watercooled one, originally installed in a GMC Syclone/Typhoon.  They're pretty easy to find used if you're patient, because the fashion now is for all the Sy/Ty people to move to air/air intercoolers.  I'd use air/air too, if it wasn't for the lousy compromises you have to make to get them to work in the back of a van.
Here's the Sy/Ty heat exchanger that I bolted up in front of the van, where the spare tire usually lives.
My AAZ engine is installed upright at about 15 degrees, like the cars, and bolts to the original transmission with a Kennedy Engineering kit.  Most van guys here use the VW factory 50 degree install for their TDs, so this probably looks weird to them.
Anyway, here's how I originally rigged the intercooler to work with the original K03 turbo on the AAZ:
I was fairly pleased with this rad hose & exhaust pipe approach, given that I can't weld.  The rad hose never blew off once, even at 17 very hot psi of boost coming from that little turbo.
But then the tragedy.  The K03 blew up completely, very soon after I screwed the wastegate closed and jumped the boost from 12 to 17 psi.  So instead of just replacing it with another K03 (ie. the easy solution), I figured it was time to upgrade to something bigger.
Dave Cross at Passenger Performance helped me out at that point.  He sold me a 1.6TD exhaust manifold and a re-built Garrett T3 turbo, then installed it on the engine, and fabricated new steel intercooler piping.
He wanted to set up a much smoother airflow than my rad hose project, so he flipped the exhaust manifold and turbo upside down, and ran the airflow through the intercooler reversed from the way I had it going with the K03.
I think keeping the hot turbo from baking the intake manifold is a great idea, and my peak oil temps have significantly dropped, by at least 20 degrees F.  I'm not sure what specific part of this T3 install has caused that drop, or whether it's a cumulative effect.
The "upside down" approach also means that the intake and exhaust airflow is much less restricted in the tight van engine bay.  The rad hose 90 degree bends are cut out of the intercooler piping, and what's left of the "exhaust pipe" just goes straight out the back to a muffler sitting about 3 inches from the turbo housing, instead of having to make a U-turn before exiting out the back.  The new tailpipe is side exit now, so the rear window doesn't get sooty.
Reply #1April 11, 2006, 10:59:49 pm
deepmud
  • 158
« Reply #1 on: April 11, 2006, 10:59:49 pm »
I never did like my small stock AAZ turbo - I had the K14 - too small for sustained boost IMHO - better to have a bigger, higher flow turbo, give up a little bottom end torque. Or a VNT :D
the 1.9TD/Suzuki w/big tires guy
visit Alaska @ www.alaska4x4network.com
Reply #2January 10, 2007, 08:01:28 pm
speedy
  • 120
« Reply #2 on: January 10, 2007, 08:01:28 pm »
The pictures in this thread seem to have expired.  I am very interested in seeing them if anyone knows of another location where they can be viewed... please?
-Dave
Reply #3January 10, 2007, 10:20:43 pm
935racer
« Reply #3 on: January 10, 2007, 10:20:43 pm »
Boy that was a while ago! Before I had a good tig welder! I wouldn't mind seeing those pics as that was nearly a year ago and I haven't seen it since.
Reply #4January 13, 2007, 01:21:30 pm
Otis2
  • 191
« Reply #4 on: January 13, 2007, 01:21:30 pm »
That was a while ago, wasn't it.  And I recall there was a cause-and-effect relationship between you doing this work and your shiny new tig welder... :)
I'll see what I can do about the photos, but it could take a few weeks - sry, I'm travelling for work right now.  I didn't realize the photo host web site would have a time limit.
Reply #5January 13, 2007, 02:19:26 pm
Typrus
  • 93
« Reply #5 on: January 13, 2007, 02:19:26 pm »
One word. Photobucket.
1995 Toyota Camry 2.2L 5-speed
1984 Toyota Tercel 4wd Wagon 1986 "           "           "      "
1996 VW Passat TDI 1Z w/ KermaTDI Stage 3 kit
1999.5 F-250 7.3L Powerstroke
2002 Excursion 7.3L Powerstroke (Dads)
Reply #6January 16, 2007, 10:23:32 am
danfromsyr
  • 13
« Reply #6 on: January 16, 2007, 10:23:32 am »
I've just put a K14 onto my van after running a K24 and am quite happy with the instant 10lbs boost.  inmy 1980 vanagon (aircooled trans) ASI camper (heavier then westfalia by far) on 195/75/14 reinforced tires I made a 2100 mile trip to FL and back to NY in december.
after a throttle cable break down on the side of the highway and running late for our train..  yes they take vanagon campers onto the Amtrack autotrain.   I ran up I-4 at 4500rpms and an indicated 80~85mph..  few were passing me on a sunny saturday afternoon.. so I know I was moving right along.. them FL interstates can have some fast traffic..  and this time was a NY rusty vanagon w/open 2.5" header.
Quote from: deepmud
Reply #7January 16, 2007, 11:22:45 am
deepmud
  • 158
« Reply #7 on: January 16, 2007, 11:22:45 am »
what was your EGT?
