Author Topic: 1.9 head gasket on 1.6 hydro?  (Read 5143 times)
March 08, 2006, 07:51:38 am
mtnman
  • 18
« on: March 08, 2006, 07:51:38 am »
Planned on using the more robust 1.9 hg  on my late edition 1992 1.6 but the hole patterns are different. Would sure hate to block an oil or water passage. Does the 1.9 need to be altered or is it a direct bolt on?
Reply #1March 08, 2006, 09:04:22 am
chrissev
  • 694
Re: 1.9 head gasket on 1.6 hydro?
« Reply #1 on: March 08, 2006, 09:04:22 am »
Quote from: "mtnman"
I have a 1.9 head with 1.9 head gasket on a 1.6 hydro motor right now.  It runs.  Has misfire and smoke problems when it is cold.  The holes do line up though with the 1.9 gasket.  Only problem you will have is that the cylinder holes in the 1.9 gasket are slightly bigger so you lose a bit of compression.
Reply #2March 08, 2006, 04:06:06 pm
935racer
« Reply #2 on: March 08, 2006, 04:06:06 pm »
I use the 1.9 HG's on all th hydraulic lifter 1.6's that come to my shop. Seeing how yours is a 92 it should be hydraulic unless someone swapped it out for a solid lifter at some point. No modifications for the hydraulics. Do you have the headgasket flipped the right way?
Reply #3March 08, 2006, 07:57:56 pm
DVST8R
  • 535
« Reply #3 on: March 08, 2006, 07:57:56 pm »
Quote from: "935racer"
LOL! I seem to remeber a rabbit that had that problem  :roll:
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #4March 08, 2006, 11:42:56 pm
vwmike
  • 1158
« Reply #4 on: March 08, 2006, 11:42:56 pm »
My '88 Jetta has an MF hydraulic lifter 1.6TD engine and I am running a 1.9TD (AAZ) head gasket on it. Nothing special was done to make it work and I've had no problems with it at all. I would definitely recommend it.
Reply #5March 09, 2006, 04:28:18 pm
935racer
« Reply #5 on: March 09, 2006, 04:28:18 pm »
Hahaha brett that was a bad day for you, oh wait more liek a bad week, taht was some "rebuilt engine" hahaha.  AS for the AAZ HG on a 1.6 HYD I have done around 20-30 of them, works awesome. IF its not lining up and it is a hydraulic blockt he headgasket is upside down.
Reply #6March 12, 2006, 08:10:58 pm
92A2VWJTD
« Reply #6 on: March 12, 2006, 08:10:58 pm »
I agree.
The 1.9 (AAZ) HG fits real nice under my 1.6 (MF) hydraulic head. The 1.6TD tends to blow out the stock gasket due to such a small cylinder and  high compression level (plus boost). The Metal HG is the way to go, and if you can afford it, rock out some Raceware aircraft grade head studs. I couldn't when I did my HG, but can appreciate the benefits.
Reply #7March 14, 2006, 04:06:00 am
johnny
  • 26
    • http://www.silver-ranch.com
« Reply #7 on: March 14, 2006, 04:06:00 am »
Can someone tell me what is the great benefit of putting a 1.9 HG on a 1.6 ?
I drive my car now for 6,5 years with different 1.6 engines and never had gasket problems.
Reply #8March 14, 2006, 05:40:23 am
wyldman
  • 403
« Reply #8 on: March 14, 2006, 05:40:23 am »
The 1.9L is a layered steel shim gasket,which seals much better,especially in engines running a lot of boost.The stock 1.6L is just a standard style gasket.It will work fine in most applications,but for just a little bit more,you might as well use the better gasket if you ever need one.
(416)565-7282
Reply #9March 19, 2006, 03:38:31 pm
vwnut20
« Reply #9 on: March 19, 2006, 03:38:31 pm »
I believe the dealerships are starting to sell metal HG for the 1.6 td now, they around $160 for it.
Reply #10March 20, 2006, 07:10:45 am
mtnman
  • 18
« Reply #10 on: March 20, 2006, 07:10:45 am »
At my parts store I  put the 1.9 over a 1.6 and there was a difference in hole patterns. Does anyone have the part # for the aaz 1.9 2 notch HG?
Reply #11March 20, 2006, 07:34:54 am
wyldman
  • 403
« Reply #11 on: March 20, 2006, 07:34:54 am »
028 103 383 BC is the part number.
(416)565-7282
