Author Topic: Who needs "hot" injection?  (Read 5915 times)
April 05, 2009, 06:44:10 pm
dillenger1
  • 777
« on: April 05, 2009, 06:44:10 pm »
Im selling my 10mm hybrid pump.runs real strong.Peugoet hybrid with volkswagen core.Make an offer
altitude pump is good never ran it,but has new seals .all is well inside.make offer Has governor mod donethe hybrid
the fuel pin on the alt comp pump
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1April 08, 2009, 05:33:58 pm
dillenger1
  • 777
« Reply #1 on: April 08, 2009, 05:33:58 pm »
bump.Nobody needs a good injection pump?The altitude pump has the governor mod done
Reply #2April 08, 2009, 05:38:25 pm
truckinwagen
  • 1895
« Reply #2 on: April 08, 2009, 05:38:25 pm »
what kind of price range you looking at getting?
what shaft does it have?
is it just an altitude comp, or has it been converted to run boost enrichment?
83 Opel Kadett Diesel
Reply #3April 09, 2009, 03:05:49 am
dillenger1
  • 777
« Reply #3 on: April 09, 2009, 03:05:49 am »
Its been converted to run off boost.It needs a stiffer spring in the aneroid though.Ill take 125.00 for the altitude pump and 175.00 for the 10mm
Reply #4April 09, 2009, 01:38:00 pm
« Reply #4 on: April 09, 2009, 01:38:00 pm »
you built this pump right? how well did it fuel your engine? what injectors is it set up to run best with?
Reply #5April 10, 2009, 03:20:04 am
dillenger1
  • 777
« Reply #5 on: April 10, 2009, 03:20:04 am »
Yep i put it together.It fueled my engine quite well .I was running gtd nozzles
Reply #6April 10, 2009, 09:25:21 am
« Reply #6 on: April 10, 2009, 09:25:21 am »
would it run good with a set of fresh TD 155bar injectors? or is there something better about the GTD nozzles?
Reply #7April 10, 2009, 04:27:18 pm
dillenger1
  • 777
« Reply #7 on: April 10, 2009, 04:27:18 pm »
Sure.I dont think the gtd nozzles actually flow more fuel though.So any factory nozzle would work.I have the injectors to brand new nozzles just poptested and adjusted to 160 bar.
Reply #8April 18, 2009, 02:52:06 pm
dillenger1
  • 777
« Reply #8 on: April 18, 2009, 02:52:06 pm »
who needs a pump or two?
Reply #9May 03, 2009, 01:42:09 am
ryanp
  • 269
« Reply #9 on: May 03, 2009, 01:42:09 am »
dillenger1 - just a quick question, I've got a new peugeot pump coming my way, would this fit directly onto an AAZ without building it into a VW casing?
Cheers
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #10May 08, 2009, 04:09:46 am
dieselherb1
  • 354
« Reply #10 on: May 08, 2009, 04:09:46 am »
Bump
Price now?
Reply #11May 08, 2009, 07:54:41 am
myke_w
  • 1099
« Reply #11 on: May 08, 2009, 07:54:41 am »
was this built to run an MTDI?
Reply #12May 08, 2009, 10:22:50 am
« Reply #12 on: May 08, 2009, 10:22:50 am »
no, he built it to run on his 1.6 in his toyota.. think he told me he had it set up with 160 bar injectors or something..
Reply #13May 26, 2009, 01:40:05 pm
myke_w
  • 1099
Re: Who needs "hot" injection?
« Reply #13 on: May 26, 2009, 01:40:05 pm »
Does the 10mm have the lda?
