Author Topic: AAZ pump questions? WITH PICS  (Read 3556 times)
March 20, 2009, 02:32:44 pm
rixy
  • 70
    • http://www.ec-dc.co.uk
« on: March 20, 2009, 02:32:44 pm »
hi peeps, i got this new AAZ pump to fit to my ABL T4 transporter 1.9TD engine, and just wanna ask a few questions :-)
1. Is this the good AAZ pump, and not an ECO one?
2. Will the boost pipe bit from a GTD pump bolt in the top of the LDA, as its missing on this one?
3.Does this fuel screw look like its been wound in alot??
4. What does this little sender / soleniod do, and how do i connect the wires etc?? (middle bottom - see 2 cut off wires)
GTD Caddy Soon..........
Reply #1March 20, 2009, 03:26:08 pm
Hey
  • 339
« Reply #1 on: March 20, 2009, 03:26:08 pm »
This is a semi electronic pump.
It won't work just like this, you need to modify the advance system before you try it. You may try it, but I am pretty sure it won't work.
Reply #2March 21, 2009, 12:57:26 am
rixy
  • 70
« Reply #2 on: March 21, 2009, 12:57:26 am »
is this an internal modification?? how can i modify the advance system??
Is there an AAZ pump that will fit straight away??
Reply #3March 21, 2009, 02:44:19 am
gigaz2
  • 626
« Reply #3 on: March 21, 2009, 02:44:19 am »
like Hey said, that selenoid controls pump timing, just like the TDI one, you might be able to disable it and fit the guts of a normal pump, or get another pump and use this one for parts
Reply #4March 21, 2009, 05:02:57 am
« Reply #4 on: March 21, 2009, 05:02:57 am »
1. yes
2. yes
3. it still has the factory tamper proof piece on it, so no
4. Timing control as mentioned. I'm pretty sure you would need to take the whole pump apart in order to modify it. You could try it as is and it might work, but I have my doubts.
Yes, there are AAZ pumps that are a direct bolt on.
There is another sensor in between the high pressure outlets (delivery valves)
Reply #5March 21, 2009, 12:07:44 pm
rixy
  • 70
« Reply #5 on: March 21, 2009, 12:07:44 pm »
oh yeh, so there is...... ha ha......any1 wanna buy an AAZ pump? lol
