Author Topic: I made an exhaust... What do you think? (many pics)  (Read 9244 times)
February 15, 2009, 07:56:02 pm
Jettagli16v
  • 344
« on: February 15, 2009, 07:56:02 pm »
I made an exhaust for my 85 Jetta TD.
Everything is Stainless, even the innerlock liner on my flex coupling.
3" from the turbo all the way down the tunnel, and then 2.5" over the axle  and to a dump.
Here go the pics:
This is what we removed... Anyone need a perfect stock exhaust?
This is my welding compared to my friend Chuck's.... I should have stuck to tach welds....
This is the adapter from ATP to a 3" V-band.
The downpipe:
The straight piece down the tunnel, and the over-axle.
We had to piece together the tailpipe out of leftovers, but it is pretty close to what I had in mind at the beginning.
Testing its ability to paint black stripes on the ground:
My buddies shop (all the tig welding):
Reply #1February 15, 2009, 08:00:21 pm
Jettagli16v
  • 344
« Reply #1 on: February 15, 2009, 08:00:21 pm »
Also, I will have to work on a video... the noise is a breathtaking symphony.
Reply #2February 15, 2009, 08:25:23 pm
Jettagli16v
  • 344
« Reply #2 on: February 15, 2009, 08:25:23 pm »
with the tip pointed to the ground, the sound seems to go in all directions, including forward to me....
not sure if I prefer that, or not.
Reply #3February 15, 2009, 08:59:09 pm
camboscams
  • 324
« Reply #3 on: February 15, 2009, 08:59:09 pm »
I Like!!! Needs a 3 inch store bought turndown to seal that perfect exhaust!!!....IMO
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #4February 15, 2009, 10:04:00 pm
AudiVWguy
« Reply #4 on: February 15, 2009, 10:04:00 pm »
Lose the tip, every time the exhaust flow has to make a turn it creates a restriction, reducing your exhaust gas flow. The air going by the car creates a scavenging effect and helps pull the exhaust out of the pipe.
Just my 2 cents.  8)
-JB
Reply #5February 15, 2009, 10:57:33 pm
« Reply #5 on: February 15, 2009, 10:57:33 pm »
shexzi shexzi!
but I do agree about not agreeing on the last bit of the project..:lol:
Were you already done the case when you hit the axle? lol what happened to that tip it looks out of place.. maybe tuck it up under the car some more, and angle the tip (or loose it) so it doesnt make a 90 degree..
i'm sorry the rest is BEA-utiful, but dayyyumm.. wth? lol good job none-the-less! :P
Reply #6February 16, 2009, 01:23:14 am
Heavy D
  • 10
« Reply #6 on: February 16, 2009, 01:23:14 am »
lol wanna make me one but only from the turbo too the down pipe?$$
1.6turbo
Reply #7February 16, 2009, 03:42:40 am
  • 3468
    • McScrubbins Body Wash
« Reply #7 on: February 16, 2009, 03:42:40 am »
seeing the stock exhaust on the shop floor AWAY  from your car is a good feeling eh :P
Reply #8February 16, 2009, 06:31:26 am
spencebm
  • 686
« Reply #8 on: February 16, 2009, 06:31:26 am »
link to exhaust flange adapter from atp?
Ben Spencer
Reply #9February 16, 2009, 06:47:13 am
« Reply #9 on: February 16, 2009, 06:47:13 am »
Quote from: "spencebm"
/\ x 2 /\
Looks really good I think. I be however your going to end up moving the end. After a while that breathtaking symphony will get annoying.
Out the back and regardless of what everyone else has said I would still leave the turndown on it.
You have free'd up the exhaust enough it wont hurt a thing and by having that turndown on there your going to help keep the soot off the car.
Good job man looks beautiful!!  :D
Reply #10February 16, 2009, 08:08:19 am
53 willys
« Reply #10 on: February 16, 2009, 08:08:19 am »
I too would like the link to that adapter!!
your SS exhaust set-up looks great!!
you just need to cut the tip some more...turndowns are supposed to look more like this...
nice job...cut the tip and you will be golden!!!
Reply #11February 16, 2009, 09:34:44 am
rallydiesel
  • 1880
« Reply #11 on: February 16, 2009, 09:34:44 am »
Your buddy made the downpipe? That's pretty sweet. You could probably sell a few here.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #12February 16, 2009, 10:05:13 am
« Reply #12 on: February 16, 2009, 10:05:13 am »
Quote from: "rallydiesel"
I would bet you are correct!
Reply #13February 16, 2009, 12:47:45 pm
Heavy D
  • 10
« Reply #13 on: February 16, 2009, 12:47:45 pm »
I want this Ill buy one!!
1.6turbo
Reply #14February 16, 2009, 12:49:26 pm
kaneb
  • 164
    • www.dasdubbers.org
« Reply #14 on: February 16, 2009, 12:49:26 pm »
Very nice work.
I need 3" exhaust for my bunny.
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
