Author Topic: Goodbye @#^%* Exh. C-clamps!  (Read 10427 times)
April 28, 2008, 08:35:57 am
KTZed
  • 170
« on: April 28, 2008, 08:35:57 am »
My weekend handywork...sorry for the crappy cell pic.
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
Reply #1April 28, 2008, 09:27:50 am
« Reply #1 on: April 28, 2008, 09:27:50 am »
Sexyness!!
Build 2?
Reply #2April 28, 2008, 11:54:00 am
spencebm
  • 686
« Reply #2 on: April 28, 2008, 11:54:00 am »
that might outflow the stock dp, but im not sure...
Ben Spencer
Reply #3April 28, 2008, 12:32:36 pm
Dirtrag2
  • 298
« Reply #3 on: April 28, 2008, 12:32:36 pm »
looks like 2 1/2", yes?
nice work ina any case  :lol:
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #4April 28, 2008, 12:33:15 pm
Op-Ivy
  • 513
« Reply #4 on: April 28, 2008, 12:33:15 pm »
Nice! This summer I'll be doing something like this too. The "toilet bowl" part with the seal leaks and I can't get it to stop :(
Where did you source the parts and how are you going to connect it to the rest of the exhaust?
EDIT: PS, nice welds!
Reply #5April 28, 2008, 01:05:22 pm
KTZed
  • 170
« Reply #5 on: April 28, 2008, 01:05:22 pm »
Yes its 2.5" mandrel. I bought 2 "U" bends but only used one and a bit. I could have got away with just 1 "J" bend.
Its hard to see in the pic but there is a V-band flange welded to the end of the flex pipe and the clamp is on the table (freezer full of moose lol) as well.
I bought everything from http://stores.ebay.ca/Exhaust-Direct-Performance
Good prices and Jim was great to deal with there.
Edit: I bougth the V-band from http://siliconeintakes.com
Reply #6May 05, 2008, 07:12:50 pm
geetus
  • 27
« Reply #6 on: May 05, 2008, 07:12:50 pm »
Nice looking DP. I am building one too and I used yours for inspiration. Hoping to get mine welded up sometime this week.
Cheers.
Reply #7May 05, 2008, 09:36:27 pm
« Reply #7 on: May 05, 2008, 09:36:27 pm »
where did you get the flange?
Reply #8May 05, 2008, 10:52:23 pm
« Reply #8 on: May 05, 2008, 10:52:23 pm »
...and the other question I wanted to ask.... how long is the braided section ??
Thanks for sharing your great project !
Reply #9May 05, 2008, 11:27:31 pm
KTZed
  • 170
« Reply #9 on: May 05, 2008, 11:27:31 pm »
I used the 2.5 x 6 although I probably could have fit the 8". I figure longer is better as it will put less stress on the turbo/exh manifold.
Thanks for all the kind remarks. It was my first downpipe build and im rather happy with it. I also just got rid of my sidepipe exhaust as I was hitting it on everything and I half assed the hangers so it rattled. Full 2.5 mandrel turbo to bumper now with no muffler. I'll see if I can get a pic of that too.
Reply #10May 06, 2008, 06:56:54 am
« Reply #10 on: May 06, 2008, 06:56:54 am »
Quote from: "zukgod1"
Umm???
Reply #11May 06, 2008, 08:36:16 am
KTZed
  • 170
« Reply #11 on: May 06, 2008, 08:36:16 am »
The turbo flange? I made it out of some 3/8 steel plate. Just clamped the old downpipe to it to use as a drill jig.
Reply #12May 06, 2008, 09:21:52 am
« Reply #12 on: May 06, 2008, 09:21:52 am »
That sounds good to me..
I found a place that sells pre cut flanges for a reasonable price.
I think it was like $15 shipped for one..
I don't have a torch so it's tough for me to cut them out.
The last DP I made I just used a square piece of 3/8 that was WAY to big but it worked..
Were you able to keep the flange from warping while you welded it ok?
As in did it dish it out? I wasn't paying enough attention and mine was a tad warped when done, was able to just use a file to fix it  but would have been nice if I would have payed attention and not warped it.
Reply #13May 06, 2008, 09:57:01 am
« Reply #13 on: May 06, 2008, 09:57:01 am »
Do tell... I'm torchless as well ??!!!
Reply #14May 06, 2008, 10:20:40 am
KTZed
  • 170
« Reply #14 on: May 06, 2008, 10:20:40 am »
Who needs a torch when you have an angle grinder with a cutting disk  8)
I used a 2.5" hole saw to cut the centre hole (which is centred in the 4 mounting holes btw) and the exh. pipe being 2.5 OD fit perfectly inside. I welded the flange on the inside and outside to try to prevent warping and then flattened the surface with a flapper disk on the grinder.
