Author Topic: Aneroid Pins  (Read 12692 times)
March 31, 2008, 01:03:48 am
DonGTI
  • 172
Aneroid Pins
« on: March 31, 2008, 01:03:48 am »
I had previously bought a 1.6 td aneroid pin to fit in my aaz however i've been browsing in the forum and found quite a number of other pins you people use, ranging from cummins to rover.
I am using my car as a daily driver in a country where there are few long stretches of road.  At present with the AAZ in standard trim it is pulling out 42-47 mpg, however it does so with relatively gutless performance :(  would a larger/better aneroid pin maintain fuel economy or plumb it down the drain?
Which one should I go for?  The diesel pump service shop i bought the 1.6 td pin from said he would replace it with any other model i would like... but which one?
Thanks
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
                              - someone's wise words after my GTI engine died -
Reply #1March 31, 2008, 05:07:24 am
dieselweasel
  • 312
Aneroid Pins
« Reply #1 on: March 31, 2008, 05:07:24 am »
Swapping the boost pin shouldn't negatively affect fuel economy...unless you start driving it harder.
The 1.6 boost pin seems to be as good as any other from what I've read.  Also it is adjustable...the profile changes as it is rotated.
Besides, if for some reason you decide you don't like it just undo the four screws on the LDA cover, remove cover, change pin, then reassemble.  Easy as pie.
Reply #2March 31, 2008, 05:16:18 am
DonGTI
  • 172
Aneroid Pins
« Reply #2 on: March 31, 2008, 05:16:18 am »
Can I use second hand ones or they have to be new?
BUT
Reply #3March 31, 2008, 02:42:59 pm
bert
  • 423
Aneroid Pins
« Reply #3 on: March 31, 2008, 02:42:59 pm »
Don,use a second hand one,my AAZ has a larger diameter pin than the 1.6 so i couldnt interchange them,i got the rover 220TD pin and its perfect,it has the most aggressive profile that will physically fit on the pin,my AAz flies with it in,its staying,no need to change that again.
Bert
Reply #4March 31, 2008, 02:46:51 pm
James8485
  • 223
Aneroid Pins
« Reply #4 on: March 31, 2008, 02:46:51 pm »
i have a AAZ also and was going to the local junker in a couple to pick up a 1.6TD pin it wont fit you say?? or not fit in some pumps> how your fuel econemy now??
---------James--------
Reply #5March 31, 2008, 02:57:07 pm
bert
  • 423
Aneroid Pins
« Reply #5 on: March 31, 2008, 02:57:07 pm »
my pump was brand new a year ago,i took the standard useless pin out,took my old scrap 1.6 pump to bits for the pin,but when i fitted the 1.6 pin to the 1.9 pump it was about 1.5mm smaller and wobbled all over the place,the 1.9 pin wouldnt fit the 1.6 pump obviously as it was too big a diameter,so i went scrap yarding and found the rover 220TD pin,absolutley amazing performance with a T3 turbo,winds up quick too,the spring under the pin is standard, and there is no smoke screw or starwheel to adjust on the AAZ pump i have,i have not touched the fuel screw on the back of the pump its still sealed with the tamperproof cap,and theres NO SMOKE at all,im well impressed,im running 11 psi max so far,i have no intercooler either.
Bert
And the rover pin does not alter as its rotated so it can be fitted anyhow  :wink:
Reply #6March 31, 2008, 03:30:27 pm
James8485
  • 223
Aneroid Pins
« Reply #6 on: March 31, 2008, 03:30:27 pm »
CAN YOU ONLY FIND A ROVER 200TD PIN IN THE U.S?
i am from canada and havnt even heard of this vehical!
so many therorys! i was going to put the 1.6TD pin in now im stuck..
i have a K24 turbo going on soon so i need a decicion fast >>>> OH 1 more thing even if i change the pin and still leave the small stock turbo for alittle bit whats going to happen? will i still be able to drive it ok>
Reply #7March 31, 2008, 06:29:05 pm
Aneroid Pins
« Reply #7 on: March 31, 2008, 06:29:05 pm »
A Cummins pin fit in my AAZ pump. I thing it is also ground a bit deeper then the 1.6 pin.
Reply #8March 31, 2008, 06:33:35 pm
Aneroid Pins
« Reply #8 on: March 31, 2008, 06:33:35 pm »
Oh, just remembered an important bit. If you put a different pin in, put in a different spring as well. Otherwise the pin will go to full fuel with only 4 PSI. I put the Cummins spring in, and calculated it will give full fuel somewhere around 11 PSI. Otherwise you will probably be smoking all the time.
Reply #9March 31, 2008, 09:32:12 pm
DonGTI
  • 172
Aneroid Pins
« Reply #9 on: March 31, 2008, 09:32:12 pm »
different spring as in i use a spring from the pump i removed the pin from? i.e. if i put a 1.6 td pin i use the 1.6 td spring and the same for the rover one?
how much different is the cummins from 1.6? earlyer increase in fuelling?
BUT
Reply #10March 31, 2008, 10:34:55 pm
Aneroid Pins
« Reply #10 on: March 31, 2008, 10:34:55 pm »
Quote from: "DonGTI"
Yes. Probably any other spring will work with any other pin. The AAZ spring is just very weak as there was no need for a stiff one with a straight pin.
I haven't seen them side by side but from the pictures, the Cummins looks ground more.
Cummins pin and spring compared to AAZ pin and spring. Although it is shorter, the Cummins spring will work as it is stiffer. I had to open up the bottom just a tiny bit so it would fit over the steel spring seat.
1.6 pin. You can see that it looks wider than the Cummins pin at it's smallest diameter.
Reply #11April 01, 2008, 05:29:56 am
DonGTI
  • 172
Aneroid Pins
« Reply #11 on: April 01, 2008, 05:29:56 am »
Thanks Jimfoo, however I have to ask what James8485 asked... if I keep my stock turbo (K03 003) do I risk doing any damage with a better boost pin?
I'm really divided between the cummins and the rover pin... I went to the diesel pump shop and he said that he has rover 220 boost pins in stock however i have to specify which cummins boost pin i would require, so jimfoo can you tell me what engine yours came from as well as pump type?
Also... which one has the best profile for a stock turboed aaz? nothing off the wall or something that drains my tank every time i floor the pedal...
BUT
Reply #12April 01, 2008, 06:14:23 am
Aneroid Pins
« Reply #12 on: April 01, 2008, 06:14:23 am »
...You could always grind down the AAZ pin and make it look like the 1.6 one.  Shouldn't be that hard...
Reply #13April 01, 2008, 07:24:54 am
Aneroid Pins
« Reply #13 on: April 01, 2008, 07:24:54 am »
I have no idea what my pin came off. The guy just had it sitting around the shop.
Reply #14April 01, 2008, 10:58:35 am
DonGTI
  • 172
Aneroid Pins
« Reply #14 on: April 01, 2008, 10:58:35 am »
The pump shop had 13 different boost pins for cummins 4 cylinder engines... so I guess i can't go the cummins route :( over to the dilemma between rover 220 and the 1.6 td...
regards the spring i got a 1.6 td spring running around... can i use that with the rover pin?
what spring did you use bert?
BUT
