Author Topic: Interesting pics  (Read 5544 times)
December 04, 2007, 06:28:43 pm
Black Smokin' Diesel
  • 656
Interesting pics
« on: December 04, 2007, 06:28:43 pm »
This is an VW 1.8l 8v head from a MK2. The 1.6 head is probably very similar internally (as far as ports go). I knew VW heads didn't flow very well but wow...
http://forums.vwvortex.com/zerothread?id=3565824
Quote from: "secondgen"
Bone stock 1990 8V hydro head....
...the rest is pretty self explanatory...
Fun stuff. :laugh:
Few more:
Stock cam at highest lift, in the pics that have the valve open. No it's not the stock spring, it's just some light-duty one i had lying around the shop.
[/quote]
Reply #1December 04, 2007, 06:41:14 pm
Interesting pics
« Reply #1 on: December 04, 2007, 06:41:14 pm »
I've always wanted to do that to one of my spare diesel heas
Reply #2December 04, 2007, 09:57:25 pm
Op-Ivy
  • 513
Interesting pics
« Reply #2 on: December 04, 2007, 09:57:25 pm »
Beautiful!
Reply #3December 04, 2007, 10:34:18 pm
shegel
  • 312
Interesting pics
« Reply #3 on: December 04, 2007, 10:34:18 pm »
wow.. this helps me a lot with my understanding of heads and how they go together...keep in mind that 1 know about diesels but am just starting to work on them myself
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #4December 04, 2007, 11:28:23 pm
Interesting pics
« Reply #4 on: December 04, 2007, 11:28:23 pm »
it looks like if some of the blue area was removed, the structural integrity of the head would be drastically reduced...  someone should make a full blown custom head built from the ground up :)
Reply #5December 05, 2007, 06:19:06 am
QuickTD
  • 1156
Interesting pics
« Reply #5 on: December 05, 2007, 06:19:06 am »
I actually think the 1.9 diesel head is a bit better in terms of port design than the gasser. I have some cutaway pics, credit to Dr Diesel for the sawing.
Reply #6December 05, 2007, 07:47:45 am
Interesting pics
« Reply #6 on: December 05, 2007, 07:47:45 am »
maybe the better airflow is what gives the 1.9 more low end torque?  would be interesting if the 1.9 head could be modified enough to work properly on a 1.6 without too much difficulty.  i wonder if it would make the 1.6 more of a torque monster?
Reply #7December 05, 2007, 08:48:46 am
Interesting pics
« Reply #7 on: December 05, 2007, 08:48:46 am »
longer stroke is a huge contributer
Reply #8December 05, 2007, 03:23:07 pm
Baxter
Interesting pics
« Reply #8 on: December 05, 2007, 03:23:07 pm »
Certainly food for thought with respect to tidying the ports up with a die grinder!
Cheers for re-posting.
 8)
Reply #9December 05, 2007, 04:15:56 pm
subsonic
  • 1836
Interesting pics
« Reply #9 on: December 05, 2007, 04:15:56 pm »
Quote from: "jtanguay"
It's a straight bolt on for the 1.6 hydro.  That's the Franken.  If you have Good compression and plugs, and the top end is in good shape it should be no problem starting for daily driving.
Reply #10December 07, 2007, 06:17:40 pm
  • 656
Interesting pics
« Reply #10 on: December 07, 2007, 06:17:40 pm »
Quote from: "QuickTD"
Those ports do look a lot better flowing than the 8v ones. There's a lot less room for improvement. Anyone have 1.6 cut outs? Hmmm thinking about it, I've got two cracked 1.6 heads...
Reply #11December 08, 2007, 05:01:43 am
stewardc
Interesting pics
« Reply #11 on: December 08, 2007, 05:01:43 am »
I think the 1.9 AAZ head is slightly better, but mine did get a lot of porting work.
