Author Topic: FS: Garrett GT2052 turbo  (Read 5611 times)
August 08, 2007, 10:41:45 am
Spulen81
  • 103
« on: August 08, 2007, 10:41:45 am »
I have a brand new GT2052 for sale. I bought a pair of these and only need one. This would be a nice upgrade for a TDI or a TD. This is a brand new turbo from Garrett from a Perkins application. It has a standard T25 flange and a internal wastegate.
Specs
GT2052 COMPRESSOR TURBINE
Compressor:
Wh Dia Trim A/R
Ind Exd
37.6mm 52.2mm
Trim A/R
52 0.51
Turbine:
Wh Dia Trim A/R Type
47.0mm 72 0.50 Wastegated
$450 shipped in the lower 48
http://www.turbobygarrett.com/...1.htm
'86 4Runner TDI SOLD
'91 GTI - TDI converted
Reply #1August 21, 2007, 07:05:08 am
TD_Bunny
« Reply #1 on: August 21, 2007, 07:05:08 am »
I am assuming this could replace a stock T3 off of a 1.6TD? If not what would be needed to make this turbo fit? thanks
Reply #2August 21, 2007, 07:10:38 am
Spulen81
  • 103
« Reply #2 on: August 21, 2007, 07:10:38 am »
It won't directly bolt up.  You have the trapezoid shaped flange on your T3.  The flange on this turbo is a standard t25 rectangular flange.  You would have to make an adapter to bolt it up to the stock manifold.  The downpipe flange is different also.
Reply #3September 27, 2007, 11:46:07 am
Spulen81
  • 103
« Reply #3 on: September 27, 2007, 11:46:07 am »
Dropped the price a little.  I have another one these with a non wastegated .60 AR hotside for sale also.
